How's it leakn? Did you cut the hole wrong? Isn't there a gasket on the sub? You can use the caulk cord or the gasket material..but gorrilla tape works on the outer edge well if your flush mounted
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
good man.
I used weather stripping for my sub and my front stage. Totally worth $5.
2007 Pacifica
Yea of course with my luck I still have a couple of leaky spots but I'm gonna fix em tomorrow they're not that bad and not even close to how bad it was before I sealed it..... And I lost about 1-2 tnuts on each sub when I removed the subs they fell out :(
  • Who's Online   0 Members, 0 Anonymous, 1545 Guests (See full list)
