your headunit sub level should be at +15 iirc and RCAs do not clip at/near full volume of 35
as your voltage drops you will clip the amp sooner, which is also what is happening.
basically you arent even running the amp full power at all, if you were... you would have more issues than "low 13s"
(n8 pioneers usually are clean full voltage at sub level 0 to +2)
Edited by Decaf
I am an anti pioneer advocate so Im not familiar with them. If they cant be bothered to fix the pico fuse issue that would cost about two bucks to do I can't be bothered to run their stuff.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Well I guess I need to get these other two batts installed and re tune the amp.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
Im not sure sure id worry about it with 3-4 times the rated wattage on them. It was more of a for your knowledge type thing. You retune your amp now and you mgiht send a cone flyingh.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yeah I'm really not worried about retuning right now as I doubt I'm.clipping and the subs are already getting more than enough power, when I upgrade in the future ill make sure to tune with a dd-1 though.
  • Who's Online   0 Members, 0 Anonymous, 2747 Guests (See full list)
