Scion Tc daily driver to show worthy project.
the stanley is actually smaller than what your thinking, its 2" high so great for car audio. the other one i got at michaels arts and craft store it is a 5x7 photo holder box
ok awesome thanks. i may go look at them in person. there's a hobby lobby near my work that might have something similar
finally got some time today. took out the seat belts. ran into a little issue. the connector is a bit tough. looked it up and you need to remove the black snap keeping the yellow connector in place.
i started to lay the rca cables and the remote wire
i then moved onto the b pillar
i ran the wires for the tweeter. i did not want to remove the dash so i removed the 2 corner bolts just enough to run the wire
the top bolt near the top of the dash
the bottom bolt near the kick panel
the finished run
i ran the wire through the factory grommet from the door
the weather was so nice i used it to install the fat mat in the rear seat
and i even managed to finish the passenger door
and this is why you dont by razor knives in a dollar store lol
i am mounting the tweeters on the dash for better imaging. i pulled the dash up just enough to get the wire underneath the lip . It was a PAIN , but turned out good.
i then went about choosing a location for the Audiocontrol Matrix and settled on the glove box as i dont need the space for anything.
Then i had a little time to vibration dampen the trunk
I made the connections for the door speakers and the tweeters. Not bad for a mornings work.
