daniel1204 Posted March 21, 2012 Report Posted March 21, 2012 I Have a SAZ-2500D And 4 12' Subs , They are all dual 4's 500w rms each, I can wire it to 2 or .5 ohms i want to give them rated they need 2000w Max Rms Power. My question is and i have asked this before but never got an answer. I know it isnt reccomended to wire and amp to .5 but i have a theory this is without box rise and any form of impediance rise, on the clamp test it put out about 3,300 at .25ohms. It it an equal amout of stran on the amp to have it wired to 1 ohm and push 2500w rms this is without box rise and any form of impediance rise, than to be wired to .5 and supply less than rated power it will have solid electrical and all that is needed just the gain will be adjusted accordingly. Another example would be Compare thr amp supplying 2500wrms at 1 ohm, Comared to the amp wired to 0.25ohm and only supplying 600wrms, Would i still be at risk of frying yhe amp even with solid electrical? If you dont understand ask some questions Thanks in advance i am serously confused. I Am Never Wrong, Just Often Mistaken......
bdog Posted March 21, 2012 Report Posted March 21, 2012 you will be going out of warranty but that amp will handle .5 ohm no problem if you have good voltage . install a volt meter to make sure your not dipping under 12v and i believe that amp will do 3300 rms @ .85ohm @14v REP
Real96SS Posted March 21, 2012 Report Posted March 21, 2012 Dude did your last topic not give you enough info? Everything you needed to know was in that topic. I have yet to hear anyone say that they have no box rise so get that out your head. Also if you need to ask if its okay to do something then its probably a smart thing not to do it. If you dont feel comfortable dont do it. Plain and simple!!! Vehicle 2007 Chevrolet Avalanche(Co-Co) DNX9980HD 6 Team Fi 15's(King Edition) 3 DC 9k's 8 Nendo PWX 8's 4 Custom Steg 4" Super Tweeters 1 DC Audio 175.4 1 DC Audio 90.4 Rockford 360.3 3 DC Power 370xp Alts(Externally regulated) 21 D1600's 2 D4800's All SMD RCA's AudioTechnix Deadner Viper Alarm My YouTube- http://www.youtube.c...NG?feature=mhee Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/ Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
daniel1204 Posted March 21, 2012 Author Report Posted March 21, 2012 Nah sorry about the re post, And the reason i assumed no box rise was for the sake of the example i am given the understanding that the amp will proably never see the .5 ohm because of box rise and and other factors. I Am Never Wrong, Just Often Mistaken......
Real96SS Posted March 21, 2012 Report Posted March 21, 2012 Exactly so again and nicely.......Run them at .5 and as long as its good clean power(Set with DD-1 or O-scope) you will be okay. if your worried about blowing your subs or something else keep them at 2ohms for safety. KING OUT!!! Vehicle 2007 Chevrolet Avalanche(Co-Co) DNX9980HD 6 Team Fi 15's(King Edition) 3 DC 9k's 8 Nendo PWX 8's 4 Custom Steg 4" Super Tweeters 1 DC Audio 175.4 1 DC Audio 90.4 Rockford 360.3 3 DC Power 370xp Alts(Externally regulated) 21 D1600's 2 D4800's All SMD RCA's AudioTechnix Deadner Viper Alarm My YouTube- http://www.youtube.c...NG?feature=mhee Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/ Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
