it requires proper integration, and since i have seen or heard nothing about a kindle install im sure there are not any products available for it.
where as the ipad there are pre-fiberglassed housings kits you just fiberglass on your work area/dash kit where you want it, there are 90º inputs for installation, and extension
here are the parts you NEED
http://store.soundma...-ipad-1-2-or-3/
http://store.soundma...ee-passthrough/
http://store.soundma...xtension-cable/
to make your installation only easier, now what are you going to use to transfer your signals to your amplifiers? you'll need a pretty badass processor of some sort, which soundman highly recommends a unit such as this:
http://store.soundma...udison-bit-ten/
those normally run $999.99, sure you can use a cheaper type of one you can find for about 300, but you are going to be severely limited to your options as the bitONE allows a high level input from the ipad and transfers signal out of the outputs which lead to your amps for a solid clean signal
all in all, after all needed equipment is purchased (to do it properly) you'r gonna be about 1700-2000 in the hole, and about 10 hours of work to get it done
i dont recommend doing an ipad install or any sort of tablet-dash install if you aren't experienced any bit in fiberglassing.
just my .02
edit:
it will also depend highly on your vehicle and your current dash setup, it could involve some sever modification. some dashes require blocking of vents, completely modifying the HVAC controls to a separate area, and just all around a lot of work.
Edited by BeAlLsTaR13
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
Do you have to take the ipad out when it gets cold or very hot? I had an ipad sit in my truck on a hot day it it read temperature across the top. And I had to move it to cool it down.
Basshead-in-Training
wow!! i didnt know all of the parts are that expensive. i just called my local audio shop/friend and he said what he does is run it off of bluetooth audio from a deck. he hides the deck though. but thats all i got from him trying to explain it to me. could something like that work? and thanks beallstar for giving me the links and explaining everything. the only reason why i said kindle is because it has a smaller screen and can fit on my dash a lot easier than a ipad and it is a lot cheaper also.
hopefully the guys who did nook installs can chime in and explain how they did theirs
Edited by ilovebass808
I used the PAC IS76 pro for my iPad install. It gives you 5v RCA output just use a LC-1 for volume control. Use y splitters to send signal to a 4 channel amp for the speakers and the a amp for the sub.
http://Bhirst.com My portfoilo and blog!
2005 Nissan 350z with an iPad install and a dd 2508
http://www.stevemead...ll-and-dd-2508/
2002 Chevrolet Cavalier
http://www.stevemead...n-half-for-fun/
you need a line out cable for ipad with RCA connectors or a line out with 3.5 mm jack, you will need to get an adapter to RCA if you go this route. the Rcas will then connect to the jl line driver and then out to an amp.
i custom made mine with a hand full of parts and cables.
also you may not need the 90 degree connector as you can take the plastic housing off of the 30 pin connector and bend the wires the desired direciton and hot glue them there. it will give you considerable extra room. The 90 is still the thinnest option but if you got the room you can save about $70. I dont know where soundman gets em but I cant find them anywhere else. $70 is just bit high for some thing I know can be made for less than a few bucks.
Edited by rogue
