ilovebass808 Posted March 22, 2012 Report Share Posted March 22, 2012 What kind of things are needed so that I could use the kindle or the iPad as a headunit? I'm probably going to go with the kindle fire because it smaller and cheaper than the iPad. Quote Check out my build! http://www.stevemeadedesigns.com/board/topic/129983-99-chevy-s10-build-log/ Link to comment Share on other sites More sharing options...
ilovebass808 Posted March 22, 2012 Author Report Share Posted March 22, 2012 Bump! Need some help guys Quote Check out my build! http://www.stevemeadedesigns.com/board/topic/129983-99-chevy-s10-build-log/ Link to comment Share on other sites More sharing options...
BeAlLsTaR13 Posted March 22, 2012 Report Share Posted March 22, 2012 (edited) it requires proper integration, and since i have seen or heard nothing about a kindle install im sure there are not any products available for it. where as the ipad there are pre-fiberglassed housings kits you just fiberglass on your work area/dash kit where you want it, there are 90º inputs for installation, and extension here are the parts you NEED http://store.soundma...-ipad-1-2-or-3/ http://store.soundma...ee-passthrough/ http://store.soundma...xtension-cable/ to make your installation only easier, now what are you going to use to transfer your signals to your amplifiers? you'll need a pretty badass processor of some sort, which soundman highly recommends a unit such as this: http://store.soundma...udison-bit-ten/ those normally run $999.99, sure you can use a cheaper type of one you can find for about 300, but you are going to be severely limited to your options as the bitONE allows a high level input from the ipad and transfers signal out of the outputs which lead to your amps for a solid clean signal all in all, after all needed equipment is purchased (to do it properly) you'r gonna be about 1700-2000 in the hole, and about 10 hours of work to get it done i dont recommend doing an ipad install or any sort of tablet-dash install if you aren't experienced any bit in fiberglassing. just my .02 edit: it will also depend highly on your vehicle and your current dash setup, it could involve some sever modification. some dashes require blocking of vents, completely modifying the HVAC controls to a separate area, and just all around a lot of work. Edited March 22, 2012 by BeAlLsTaR13 Quote Team Sundown Audio**CURRENT** -- 2012 Scion tC Build Click Here **OLD** -- 2002 Pontiac Grand AM Build Click Herecheck them out, slap me a comment2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.-------------------------------------------------------------------Head Unit - Alpine CDA-9887Subs - 2x Z 12 v.2s - v.3 + NS Soft partsAmplifier - Sundown Audio SAZ-3500DEnclosure - 3.33 Cubes tuned to 34.66hzFront Stage - JBL P660c 6.5" ComponentsRear Deck - Powerbass 4xl 6.5" Mid-RangeFront Stage Amplifier - Sundown Audio SAX-100.4DWires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAsElectrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700Videos - http://www.youtube.com/user/BeAILsTaR13------------------------------------------------------------------- Link to comment Share on other sites More sharing options...
JWBryant Posted March 23, 2012 Report Share Posted March 23, 2012 Do you have to take the ipad out when it gets cold or very hot? I had an ipad sit in my truck on a hot day it it read temperature across the top. And I had to move it to cool it down. Quote Basshead-in-Training Link to comment Share on other sites More sharing options...
ilovebass808 Posted March 23, 2012 Author Report Share Posted March 23, 2012 (edited) wow!! i didnt know all of the parts are that expensive. i just called my local audio shop/friend and he said what he does is run it off of bluetooth audio from a deck. he hides the deck though. but thats all i got from him trying to explain it to me. could something like that work? and thanks beallstar for giving me the links and explaining everything. the only reason why i said kindle is because it has a smaller screen and can fit on my dash a lot easier than a ipad and it is a lot cheaper also. hopefully the guys who did nook installs can chime in and explain how they did theirs Edited March 23, 2012 by ilovebass808 Quote Check out my build! http://www.stevemeadedesigns.com/board/topic/129983-99-chevy-s10-build-log/ Link to comment Share on other sites More sharing options...
bhirst Posted March 23, 2012 Report Share Posted March 23, 2012 I used the PAC IS76 pro for my iPad install. It gives you 5v RCA output just use a LC-1 for volume control. Use y splitters to send signal to a 4 channel amp for the speakers and the a amp for the sub. Quote http://Bhirst.com My portfoilo and blog! 2005 Nissan 350z with an iPad install and a dd 2508 http://www.stevemead...ll-and-dd-2508/ 2002 Chevrolet Cavalier http://www.stevemead...n-half-for-fun/ Link to comment Share on other sites More sharing options...
ilovebass808 Posted March 23, 2012 Author Report Share Posted March 23, 2012 How'd you control the volume and all that? From a EQ? I think that's what one gonna have a hard time on is finding a kit for the kindle. Quote Check out my build! http://www.stevemeadedesigns.com/board/topic/129983-99-chevy-s10-build-log/ Link to comment Share on other sites More sharing options...
rogue Posted March 23, 2012 Report Share Posted March 23, 2012 You dont have to have a bit one to do an ipad install. Im certain it is the best option but Im using just a JL CL-RLC and it sounds as good as any setup i have had. Quote BMW X5 Stealth Build w/ IPAD BMW 325i Rear Deck Digital Designs Build BMW 325i Car PC Touchscreen Bezel Build Link to comment Share on other sites More sharing options...
ilovebass808 Posted March 23, 2012 Author Report Share Posted March 23, 2012 How'd you Plug it into the iPad? Lol sorry I'm just making sure Quote Check out my build! http://www.stevemeadedesigns.com/board/topic/129983-99-chevy-s10-build-log/ Link to comment Share on other sites More sharing options...
rogue Posted March 23, 2012 Report Share Posted March 23, 2012 (edited) you need a line out cable for ipad with RCA connectors or a line out with 3.5 mm jack, you will need to get an adapter to RCA if you go this route. the Rcas will then connect to the jl line driver and then out to an amp. i custom made mine with a hand full of parts and cables. also you may not need the 90 degree connector as you can take the plastic housing off of the 30 pin connector and bend the wires the desired direciton and hot glue them there. it will give you considerable extra room. The 90 is still the thinnest option but if you got the room you can save about $70. I dont know where soundman gets em but I cant find them anywhere else. $70 is just bit high for some thing I know can be made for less than a few bucks. Edited March 23, 2012 by rogue Quote BMW X5 Stealth Build w/ IPAD BMW 325i Rear Deck Digital Designs Build BMW 325i Car PC Touchscreen Bezel Build Link to comment Share on other sites More sharing options...
