Hi!
so currently i have a ˝spare˝ sub while my RE audio SX broke, and i am in need of a slot ported box
the tuning frequency would be 32hz
my max trunk dimensions are 82cm / 32,283inch widith, 40cm / 15,748inch height and 52cm / 20,472 depht
the sub is Ground Zero 120spl / 30spl more info::
Diameter: 30 cm / 12"
Power handling: 1000 WRMS
Impedance: 2 x 2 Ohm
Voice coil: 63 mm / 2.5"
Excursion: X max. 20 mm / 0.8"
Resonance Frequency: FS 33 Hz
SPL 2.83
V/m: 92 dB
thanks in advance
Edited by gally
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
bump for info?
I would guess ~1.5-2 cubic feet to ~35hz
I doubt many people have experience with them.
How much power do you plan on running?
it recomends around 1.8 - 2.2 cubic feet
i plan on running about 1200wRMS clean power
You may try this:
Enclosure Specifications:
Fb = 35 Hz
Vb = 2 ft^3
External Height = 15 in
External Width = 23 in
External Depth = 18 in
Port Width = 2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 23 x 15
Left & Right Sides = 15 3/4 x 13 1/2
Top & Bottom = 23 x 15 3/4
L Port Internal Assembly Parts:
Front to Back = 13 3/4 x 13 1/2
Extension = 7 x 13 1/2
Assemmles like this:
thank you sir!
  • Who's Online   0 Members, 0 Anonymous, 672 Guests (See full list)
