Ba55h3ad651 Posted March 27, 2012 Author Report Share Posted March 27, 2012 The pos on my second batt hit the metal in my trunk n now my voltage is all messed up n i can turn the subs up to like 15 n anything past that the amp goes into protection then turns back on Quote Link to comment Share on other sites More sharing options...
CHEVY4X4BLAZER Posted March 27, 2012 Report Share Posted March 27, 2012 Get a dmm to check your voltages at the battery. Then the amp. Maybe you messed up a grounding point. Quote Link to comment Share on other sites More sharing options...
Ba55h3ad651 Posted March 27, 2012 Author Report Share Posted March 27, 2012 Dmm? Quote Link to comment Share on other sites More sharing options...
412 CVX Posted March 28, 2012 Report Share Posted March 28, 2012 digital multi meter Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
Ba55h3ad651 Posted March 28, 2012 Author Report Share Posted March 28, 2012 I got that and everything is reading fine so idk what's the prob I'm almost ready to give up it's pissin me off Quote Link to comment Share on other sites More sharing options...
01ExSport Posted March 29, 2012 Report Share Posted March 29, 2012 I assume you didn't have a fuse before your battery in the trunk? You could try taking that battery out of the equation and see what that does. Quote Link to comment Share on other sites More sharing options...
Ba55h3ad651 Posted March 29, 2012 Author Report Share Posted March 29, 2012 From my amp to my 2nd batt I do Quote Link to comment Share on other sites More sharing options...
bang'in in ga. Posted March 29, 2012 Report Share Posted March 29, 2012 i'm guessin you are grounded in or around same area the pos wire hit body, and if so that meens you sent power into the amp by way of ground, not sure but thats not good.............could have discharged your amp and poss. messed up cap's in it ..........just a guess....... Quote Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO Pioneer DEH-3400-UB Vega 65 cs & 1" tweets & T3 4" coax in Front 1- Dual 300 with an AQ sticker 2-AQ sdc2.5 12's 1- AQ 1200D.1 Monster Cable RCA's Monster Cable 4-awg Custom 4 th order box ( by DBC ) Crescendo FT1's in rear- 1/0 Big Three Opti Blue top in back for Mono Amp Stinger Power dis. block 125 amp breaker at front batt. Stock Alt. Link to comment Share on other sites More sharing options...
Real96SS Posted March 29, 2012 Report Share Posted March 29, 2012 Well your saying that without the remote wire hooked into the amp your batteries read 14 but with it connected they read 13? If so it sounds like either your amp has a problem or possibly your headunit. Do you have another amp you could swap in? Grounding out the positive on a battery doesnt do anything to the battery but it screws up anything in between. I have done this before and it was my amp that was jacked up. Quote Vehicle 2007 Chevrolet Avalanche(Co-Co) DNX9980HD 6 Team Fi 15's(King Edition) 3 DC 9k's 8 Nendo PWX 8's 4 Custom Steg 4" Super Tweeters 1 DC Audio 175.4 1 DC Audio 90.4 Rockford 360.3 3 DC Power 370xp Alts(Externally regulated) 21 D1600's 2 D4800's All SMD RCA's AudioTechnix Deadner Viper Alarm My YouTube- http://www.youtube.c...NG?feature=mhee Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/ Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/ Link to comment Share on other sites More sharing options...
bang'in in ga. Posted March 29, 2012 Report Share Posted March 29, 2012 Well your saying that without the remote wire hooked into the amp your batteries read 14 but with it connected they read 13? If so it sounds like either your amp has a problem or possibly your headunit. Do you have another amp you could swap in? Grounding out the positive on a battery doesnt do anything to the battery but it screws up anything in between. I have done this before and it was my amp that was jacked up. 2x- sounds like amp............... Quote Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO Pioneer DEH-3400-UB Vega 65 cs & 1" tweets & T3 4" coax in Front 1- Dual 300 with an AQ sticker 2-AQ sdc2.5 12's 1- AQ 1200D.1 Monster Cable RCA's Monster Cable 4-awg Custom 4 th order box ( by DBC ) Crescendo FT1's in rear- 1/0 Big Three Opti Blue top in back for Mono Amp Stinger Power dis. block 125 amp breaker at front batt. Stock Alt. Link to comment Share on other sites More sharing options...
