Which amp should i use for coaxial?
khaotickyle
I have four 4ohm coaxial speakers running about 70 watts each. I wasn't sure whether to us a 2 channel or 4 channel and how many watts the amp should be. Since the 2 channel has only 2 sets of postive and negatives, is it fine to run to 2 speaker to one set?
If you already own the 2 channel then you can wire up a pair of coaxials to each other then to each channel and the amp will see 2 ohms so it will be 2 speakers on one channel and 2 speakers on another. A 4 channel would be better and since the coaxials are 70w rms each look for a 4 channel that is at minimum 70w x 4 @ 4 ohms (you can get a stronger amp if possible just be easy on the gains). What is the rms on the 2 channel you have at 4 ohms and at 2 ohms.
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
Yeah, the coaxials would work on a 2 channel if you wire 2 of them in parallel, and put it in each channel, and whether you get the 4 channel or 2 channel, it should match the rms of the coaxials just to be safe.
Edit: Damn, got ninja-ed lol
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
If you ran two 4 ohm speakers off of a channel that would b two ohms per channel. See what the power is at 1 channel and what power is at 1 channel bridged. Why not just get an mb quart 80x4 ? And run 4 channels?
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
the 2 channel has
100 Watts x 2 @ 4-Ohm
200 Watts x 2 @ 2-Ohm
400 Watts x 1 @ 4-Ohm Bridged RMS
the 4 channel has
50 Watts x 4 @ 4-Ohm
100 Watts x 4 @ 2-Ohm
200 Watts x 2 @ 4-Ohm Bridged RMS
  • Who's Online   0 Members, 0 Anonymous, 1111 Guests (See full list)
