Well the first box I ever built was for a friend and the box was sealed and too small and it was a disaster. I now have an awesome design thanks too 412 CVX. So I was just wondering if I could get some suggestions like:
What type of screws
is Silicone caulk ok to seal the inside?
Best method to connect the subs? (bolts, terminals, ect.)
And thats all I can think of so far so any other type of suggestions would be very helpful!! Thanks in advance.
2002 Ford Explorer XLT
Front Stage: Crescendo CCX 6.5's
Rear Stage: ???
Two 15" Powerbass M154
Audiopipe AP15001d
Pioneer DEH-P5100UB
What type of screws
and you call yourself a ninja
:jon:
:madsign:
:ninja:
Edited by sensai_v3.6
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
I also am building a box soon as well. For ME i use 1.5 framing screws with square heads, cheapest caulking i can find, and i run threaded rod through the box. I may for this build do direct wires from subs to the amp and caulk around the wire to seal it off. Less breaks = more power (not that i will notice).
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
if you take your time and build the box properly you should not have to worry about using caulk to seal it
take the time sand all your mdf before you put on generous coat of wood glue screw er in wait for glue to dry and done
there was good post/thread long ago by huge-erection haha bout mfd prep
R.I.P!
(Nov-29-2009)
92 explorer
current build
Ok I'll take a look a the framing screws, thanks.
If you use enough wood glue when connecting the joints, you won't need caulking.
Really? I thought it was necessary to caulk as an added precaution.
I need to find that! Thanks. I just dont wanna mess this one up.
Rear Stage: ???
Audiopipe AP15001d
Pioneer DEH-P5100UB
Yeah I may do it, not sure yet. Any suggestions on how to do the terminals? Someone on here did a push-pin style terminal on both side of the box and it looked awesome, I cant find the thread but I would love to do that.
Rear Stage: ???
Audiopipe AP15001d
Pioneer DEH-P5100UB
Bolts or Wire out the port I say on the terminals.. The cheap plastic insert ones like the ones that come on prefab boxes tend to leak air.
Yeah, I do NOT want to do those at all. Im searching on google now trying to find those push connectors, the way the guy did it on here looked really cool, I just cant seem to find JUST the connectors without them already being in one of those cheap plastic ones.
Rear Stage: ???
Audiopipe AP15001d
Pioneer DEH-P5100UB
  • Who's Online   0 Members, 0 Anonymous, 1046 Guests (See full list)
