Well I tried to calibrate my low pass filter, i follow every step that the manual said but once i change the switch on my sundown 100.4 from full pass to lpf the signal light turns off, and when i keep it on full nd click read it says on turning down but i do and it does not change what's so ever, any idea on things im not doing incorrectly?
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
I believe every time you use the unit or change settings on amp you need to turn off and turn back the cc-1.
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
I have done that
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
on your low pass did you turn it all the way then adjust and vice versa on your high pass then adjust and take your time as you could be going over its point of matching make sure your playing a track with what your setting too
Edited by wwjm
I have no reason to use the hpf setting on the amp I have 4 mids to two sets bridged on each channel, I haven't touched the hpf since I bought it and it the correct tone its on track 22 which is 5,000hz test tone I mean all goes fine it read signal in a green light but once I flip it to log the signal light goes away and I try to turn up the hi volume to unclipped Max and still nothing
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
if i understand you right try turning the volume all the way down the gain all the way up and adjust from there it is in low pass mode now right unplug switch to low pass then continue
Edited by wwjm
no, that's incorrect in what im trying to say I follow all the steps I believe up to maybe 8? Where it says turn headunit volume up until it has a green signal light because if it's red that's to much and I have to lower it, so I did that but it tells you, that your amp has to be on full pass when you are doing this everything from that point works 100% then it says turn to lpf and press read and start calibrating, well my issue is when I flip the switch to lpf the signal light turns back off so now I can't tune it
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
bump...
Nobody knows??? I'm sure I don't have a defective cc-1 I mean it could happen but I find it very unlikely since they hand test every single one, what could be the issue im having, I don't want to throw it away or waste more money and a different product to adjust my crossovers
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Bump
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
