KnockinthaStreetzof608 Posted March 27, 2012 Report Share Posted March 27, 2012 Well I tried to calibrate my low pass filter, i follow every step that the manual said but once i change the switch on my sundown 100.4 from full pass to lpf the signal light turns off, and when i keep it on full nd click read it says on turning down but i do and it does not change what's so ever, any idea on things im not doing incorrectly? Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
Mario928 Posted March 27, 2012 Report Share Posted March 27, 2012 I believe every time you use the unit or change settings on amp you need to turn off and turn back the cc-1. Quote Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted March 27, 2012 Author Report Share Posted March 27, 2012 I have done that Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
wwjm Posted March 27, 2012 Report Share Posted March 27, 2012 (edited) on your low pass did you turn it all the way then adjust and vice versa on your high pass then adjust and take your time as you could be going over its point of matching make sure your playing a track with what your setting too Edited March 27, 2012 by wwjm Quote Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted March 27, 2012 Author Report Share Posted March 27, 2012 I have no reason to use the hpf setting on the amp I have 4 mids to two sets bridged on each channel, I haven't touched the hpf since I bought it and it the correct tone its on track 22 which is 5,000hz test tone I mean all goes fine it read signal in a green light but once I flip it to log the signal light goes away and I try to turn up the hi volume to unclipped Max and still nothing Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
wwjm Posted March 27, 2012 Report Share Posted March 27, 2012 (edited) if i understand you right try turning the volume all the way down the gain all the way up and adjust from there it is in low pass mode now right unplug switch to low pass then continue Edited March 27, 2012 by wwjm Quote Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted March 27, 2012 Author Report Share Posted March 27, 2012 no, that's incorrect in what im trying to say I follow all the steps I believe up to maybe 8? Where it says turn headunit volume up until it has a green signal light because if it's red that's to much and I have to lower it, so I did that but it tells you, that your amp has to be on full pass when you are doing this everything from that point works 100% then it says turn to lpf and press read and start calibrating, well my issue is when I flip the switch to lpf the signal light turns back off so now I can't tune it Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted March 27, 2012 Author Report Share Posted March 27, 2012 bump... Nobody knows??? I'm sure I don't have a defective cc-1 I mean it could happen but I find it very unlikely since they hand test every single one, what could be the issue im having, I don't want to throw it away or waste more money and a different product to adjust my crossovers Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted March 28, 2012 Author Report Share Posted March 28, 2012 Bump Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
OrionStang Posted March 28, 2012 Report Share Posted March 28, 2012 Leave your amp on lpf from the beginning. Play your tone, when you get signal, push read. Just make sure your lpf is all the way up. Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
