Check this out, how does it look?
[/url]
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
If you are going by RF specs just note that they specify Vb as the gross volume (before any displacements).
Not to say you can't pick a larger volume.
Also if this is a standard L port design then you should set the "# of common walls" box to 3.
Ok I will cross check the Vb, I was going off of 1.25-1.5 as stated by someones opinion in another topic I made. Also thank you about the port walls, completely forgot about that. Also I would like to ask, when is the point where port are per foot gets to its limits. I know a lot of people say 15+ but when does it get to the point that it starts to add negative effects to your performance.
Edit: so with the Vb your saying there needs to be 2.8cu gross?
Edited by RooTxBeeR
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
I have no idea why gross volume is important. i mean other than having a vague idea of how much airspace you need it's a pointless figure in my eyes.
net volume should be somewhere in the 2 cubic foot range depending on how much power they're getting.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
They will be going on a HPN-500 @ 1 ohm
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
The necessary port area really depends on the subs, the port area per cube is only a rule of thumb, for those subs you are usingI would go for no more than 16.
Ok how about this one? Everything seems to be in good specs. Also for the port length, the .75 will be from a extra sheet I will place on the side with the port/sub.
Edit: Also this if I change the common port walls to 2 for a centered port, and change the hieght to 19" all the stats are identical except 2 which are off by .02
Edited by RooTxBeeR
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
No I don't, sub up port up, my port height is the depth of the box minus wood thickness.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Ok, check the port upward, sub upward then (guess nothing will change though).
Edited by Joe X
