Need a Straight Answer - Wiring
Pick up both pieces.
Looks maybe but copper is like 2x the weight
Just do it right once, instead of shitty multiple times.
Ask around, tons of people will say the same thing.
Actually spend less money doing it correct once.
^^ yea exactly what im thinking. if 1 OFC run = about 2 CCA runs? correct? maybe a lil less than 2. then price is equal. plus then i only have hassle of concealing 1 run instesad of 2 and leave room for upgradign later. thanks again!
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Well this "know it all" says that calculator is pretty nifty. One should always shoot for less than 3% voltage drop in any circuit. Keep in mind that a 17' run to the amplifiers with a 3 foot ground to the frame in the rear and then a 2.5 foot ground from frame to battery up front = 22.5 feet, assuming the frame has ZERO resistance, which it doesn't.
In order to be fair, one should always use 50% of the maximum current requirements of the amplifier(s) as a rough idea of how much current will be required when reproducing music.
That can be calculated as follows:
Actual RMS Power / efficiency at operating impedance / desired operating voltage / 2
IE - 1,000 Watts RMS / 75% eff / 14.4 VDC / 2 = 46.30 Amps
If you play sine waves or your collection of music has the word "Bass" in every album title this will be higher . . .
Damn, those pesky laws . . .
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
Ray, post up some of your voltage drop measurements - alt stud to amp (+) input . . . would be enlightening and oh so factual . . .
They dont wanna see that when using a 2000 watt amp and using a single run of 1/0 that you lose over .9 just in the wire run at 17ft.
Ill do some cool tests soon
i wanna seee the facts ray!! see some tests. gime numberss!! haha so my next question is how many runs am i going to need? but thst link is very helpful in additon to snafu's input. i like it all and wannttt MOAR
BMW M340 xDrive
answers ray!!?? please :):popcorn:
BMW M340 xDrive
  • Who's Online   0 Members, 0 Anonymous, 694 Guests (See full list)
