the split VC part.
not that its blown to bits. haha
there we go :)
PS: smells like s&^% by the way -.-
Edited by Robby Holmes
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
That looks to be off an RE
I've seen them before, kinda rare IMO but neat none the less. Thanks for posting, I like to see split gap coils and variable density coils as well.-
-Drew
uhoh_45 said:
pretty sure thats how the smd is
its the 12" re audio xxx
i decided i wanted to see what the VC looked like cause i know its not like normal subs,
but i did NOT expect this
-Drew
i called RE today to ask how much a recone kit was,
and the guy (not greg) told me i should probably just send it in and let them do it due to the difficulty of reconing the xxx series.
is the split coil design why its so difficult to recone?
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
yeah i have on a re xxx lol.
Currently:
* Hybrid Audio Legathia 3-Way Active Front Stage
* (2) Morel Ultimo 12's
* (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm)
* (1) Arc Audio 1200.6
* RF 360.3 DSP
you've reconed one?
Because its a lot longer, would he hard to center in the gap. The two sets of spiders might be hard to glue
yeah i thought about the dual spider thing, and i have no idea how i'd do that
other than set the bottom one, let it dry, then to the top one?
also, before i pulled out the cone/VC i pushed down on the cone (to try and make it bottom out) and it straight did not happen.
:shok:
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
No, but the split spiders is probably the reason why it's not easy to recone.
formerly known as Blue86f150
this sux camel dicks
Its not so hard to build from scratch, and a pre assembled recone should have each spider glued to the spacer and all you do is glue it to the spider landing as well as gluing the surround to the basket edge. Finally, (with centered coil) put on the one piece cap and play.
Unless RE does something different IDK I've never reconed one of theirs.
-Drew
