Over powering..
So i have a trouble code light on my amp. Orion HCCA 2500.1. And its saying I'm basically giving it too much voltage. I have a 300 amp fuse which I intend to switch to a 250 to handle this issue. So my question here is.. "can over powering the amp cause distortion? Even at low gain? And after my fuse swap can I expect a cleaner output for a higher gain setting?"
Fuse has nothing to do with amp seeing to much voltage.. Fuse pops when amp draws to many amps.
*** Damn it! Ninja'd!!
1999 Lincoln Town Car-(build underway)
- (2) SA15s, 4th order, DAT 2500.1, O2 mids n highs, 250a alt, HC 2400, Big 3....
1994 Pontiac T/A for speeding tickets.-
- Currently on jack stands, wanting to be a real race car
"Your local forecast, all the ladies in the metro area should expect to see 8 inches tonight" - The Todd
Decaf, on 01 November 2011 - 02:38 PM, said:
i provide the ammo for destruction, the trigger finger is connected to the volume knob tho
URBAN GORILLA AUDIO
I have no experience with those amps, check your input voltage with a DMM
And see what it is. Like said before a smaller fuse will not lower your voltage
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
How high is your voltage duh
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Good to go. The reason I thought that was because my manual says any fuse larger then 250 amps will void warranty.
And my voltage stays around 14.9. So normal. And my amp is rated for up to 16v.
  • Who's Online   0 Members, 0 Anonymous, 2052 Guests (See full list)
