so here is a quick question i would like to ask....
if i do a system build with 4 350wRMS subwoofers, and they would be powered by a 1800wRMS amp is there something wrong with it??
i mean...
i opened a topic in some other site and they keep complaining about that like hell....
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
It really depends on said subwoofers.
If they are a good, reputable brand and you are feeding them clean power in a properly designed enclosure: you should be fine
like mentioned above..if they are getting good clean power you should be fine
I have personally ran more than 3x RMS to subs with no problem what so ever out of that setup...not saying you can do that with any woofer though
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
i would feed 4 re audio SR with a DD m1b......if that wouldnt go trough just 2 15 re audio SE...
I ripped the surrounds off of my RE SRx's on double their RMS rating. The coils were pretty and took the abuse, but the soft parts did not. I fed them clean 600 watts a piece and they lasted a couple years before the surrounds shredded.
so that leaves me with just 2 re audio SE 15˝ in a proper box....
i mean....i placed a question the same as here 4 re audio SR with M1b? on some other forum
and they keep complaining to give them NOT the rated power but at least 3x the power....i mean....am i missing something??
all of that would be in a sealed box of course...
Edited by gally
bumps
1400w worth of woofer with an 1800w amp. should be fine in my eyes. if you want to get technical, voltage drop and impedance rise would make you lose a few hundred watts anyway (depending on the box, of course)
well the DD M1b would be just for subwoofer break in period, later i would switch to DD m4....
