MrFree Posted April 2, 2012 Report Posted April 2, 2012 Please forgive me if the question is beyond stupid but I have to ask. A 2 channel mono block like the T1000 the is rated @1ohm 1000watts 2ohms @650watts etc... Could I wire each channel to 2ohms and get 650watts per channel R.I.P...99'Dodge Grand Caravan 03 Lancer Oz Big 3 HU-JVC KD-530 RCA's-rockerfosgate 41/2 inch Infinity mids Subs-(12's)2 Orion xtr124 Amp-Coustic600se battery-2 x stock, 1x Shuriken SK-BT20 Box-L-ported 3.562cubes@35Hz miscellaneous-stinger volt-meter, gain nob, (coming soon bass pro,eq,line drive) I dont have flex yet but damn I sound good,(coming soon....flex) Check out my HHR install Everything I install or build here:http://s1160.photobu...s/q485/MrBfree/ Also video's of my Car with the new box.http://www.youtube.c...lentGyge/videos
MrSkippyJ Posted April 2, 2012 Report Posted April 2, 2012 mono=1 it isn't 2 channels. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Omega5002 Posted April 2, 2012 Report Posted April 2, 2012 Just cause it has 2 postives, and 2 negatives doesn't mean it's a 2 channel, it's just when you hook up 2 subs on each one, it'll wire them in parallel for you, my mono amp does that also. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
TrentonLong Posted April 2, 2012 Report Posted April 2, 2012 Just cause it has 2 postives, and 2 negatives doesn't mean it's a 2 channel, it's just when you hook up 2 subs on each one, it'll wire them in parallel for you, my mono amp does that also. i like you.
