tuning help
Well it seems like all your numbers are correct but if your tuned to 35 i would turn that ssf up to no lower than 31.Try setting your amp up with a dd-1 and cc-1 if possible cause you may thing your ssf is 20 but it could be something else.As for it hitting higher noted harder man,You can take your box and put it in my truck and it would sound different than it would in yours.You can always put it on the TL to see exactly what its peaking at.Adding bracing if you do though will raise your tuning so be careful about that if your trying to stay around 35.
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
k thx for the help. im not touching the box till the subs break in a bit and ill go from there atleast the port is removable
REP
Yeah having that removable port gives you the option to adjust your tuning.Wish I had that option.
Vehicle
DNX9980HD
3 DC 9k's
8 Nendo PWX 8's
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
21 D1600's
2 D4800's
All SMD RCA's
Viper Alarm
He posted a picture of the box already and the subsonic being set to high is why i said he needs to use a cc-1 to set it right. Page 1
Vehicle
DNX9980HD
3 DC 9k's
8 Nendo PWX 8's
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
21 D1600's
2 D4800's
All SMD RCA's
Viper Alarm
So how about the signal you are feeding the amp with. or improper phasing of the subs.
The other thing that I was looking at is the clearance in front of the port needs to be about 14" in your case.
theres about 12 inchs but choking the port would only lower the tune i wonder if a bad rca could be the problem i used a cheap rca splitter because the deak only has one rca out for subs
REP
i may glass some in its only 2500 watts might not need it. ssf is set to 20 ish and hpf is 63
HPF 63?? or is it LPF?? :o
Pioneer 80PRS
Alpine PXA H701 w/ RUX-C701
Sundown Audio ZV3 12's
Hertz MP15K Unlimited
Hertz SPL Show SV165 x 8 pcs
Hertz SPL Show ST44 x 4 pcs
Hertz HDP4 x 2 Pcs
Mechman 300A Alternator
Shok Industries Ref Pro Cables
Audio Art 260.6XE
Custom Bus Bars
My youtube channel - https://www.youtube.com/luckyishere12345
My Current Build Log - http://www.stevemeadedesigns.com/board/topic/163038-4th-order-bandpass-wall-4-zv3-12sfrom-india/
My Earlier Build Log - http://www.stevemeadedesigns.com/board/topic/151241-2-fi-sp4s-in-a-ford-in-india/
lol ya i ment lps thx
REP
  • Who's Online   0 Members, 0 Anonymous, 618 Guests (See full list)
