Hey all. A few really, really newb questions. As you all might know I'm new to car audio but very, very interested so ...
1) I believe it's made by RF, the 3Sixty; what is it, how does it improve your system, etc? I've read about it somewhere but it, somehow, didn't help.
2) So I have come to realize some amps are "mono" and some are multi-channeled. Why is this? Just makes it easier to route to multiple subs and/or a huge amount of power can't come through one cable?
3) So what; exactly; is an ohm? I realize it's something to do with impedence or resistance, but why do we want them or don't want them? I realize this is stupid but you gotta start somewhere!
Thanks guys!
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
A multi channel amp is basically just to run more than one speaker oftenly used for powering mid bass speaker tweeter things like that a 3sixty is a signal processor and an ohm is a measurment you just have tomake sure that you subs ohm level is ok with what your amp puts out at that ohm level
1) the 3sixty.1 and 3sixty.2 are signal processors. the best out on the market right now. they allow u to tune the frequencies for your speakers so they only hit the ones u want them to hit. perfect sound quality
2)multi channel amps allow for side to side sound. mono amps will produce the same sound for all the speakers attached to it. multi channel amps can see a difference between left and right and front and back on some
3)ohms are a measure of impedance as u said b4. lower impedances are easier to get more power to. for SPL the lower the impedance the better cause power is better.
if i have said anything wrong please correct me
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
arent 3 sixtys intended for factory head units?
2003 Toyota Sequoia
Pioneer 4100dvd
Memphis PR6.5 3ways in all four doors
Memphis PR 15s (4)
Memphis PR 1.1000 (2)
Memphis PR 4.50 (1)
Optima Yellowtop (2)
Viper 5901
8000k H.I.D. kit
15% tint (2layers)
Ahh .. okay i think i get it!! or some of it at least .. thanks guys
so like for a 3 sixty that can change the frequencies ...
how do you change the power to your subs? so like i know head units often have sub adjustments but really fast .. like in steves hoe when i was in it he had litlte controls to his right of the seat that made it loudr .. thos juts "remote controls" for the amp?>
thanks so much guys
~Matthew
idk are they>?
~Matthew
which is connected to the amp?
~Matthew
Damn .. that's sick! .. thanks guys!
~Matthew
