IBleedMusick Posted April 25, 2012 Report Share Posted April 25, 2012 Why would you have to test you headunit's output ?? You should be only setting amp gains with the distortion detector ... Correct ?? Do you actually have your eq settings boosted up high enough for this to be a problem ?? Are you setting up for mids and highs ... Or sub bass ??? Um, isnt the DD-1 for both the Headunit and the amp? I dont understand why you're asking that?? I believe he asked because he didn't know, hence the question marks behind his statement. Quote 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback Link to comment Share on other sites More sharing options...
Casey Carpenter Posted April 26, 2012 Report Share Posted April 26, 2012 Why would you have to test you headunit's output ?? You should be only setting amp gains with the distortion detector ... Correct ?? Do you actually have your eq settings boosted up high enough for this to be a problem ?? Are you setting up for mids and highs ... Or sub bass ??? Um, isnt the DD-1 for both the Headunit and the amp? I dont understand why you're asking that?? I believe he asked because he didn't know, hence the question marks behind his statement. Looks like hes giving advice on something he doesnt know himself though Quote Link to comment Share on other sites More sharing options...
IBleedMusick Posted April 26, 2012 Report Share Posted April 26, 2012 Why would you have to test you headunit's output ?? You should be only setting amp gains with the distortion detector ... Correct ?? Do you actually have your eq settings boosted up high enough for this to be a problem ?? Are you setting up for mids and highs ... Or sub bass ??? Um, isnt the DD-1 for both the Headunit and the amp? I dont understand why you're asking that?? I believe he asked because he didn't know, hence the question marks behind his statement. Looks like hes giving advice on something he doesnt know himself though Looks more like he made a statement asked a question and then wanted confirmation for something he may be confused on. I don't really see any advice being given but more so a lot if questions being asked. Quote 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback Link to comment Share on other sites More sharing options...
HarryF Posted October 14, 2022 Report Share Posted October 14, 2022 Thank you tho. I had the same question. Quote Link to comment Share on other sites More sharing options...
Kyblack76 Posted October 14, 2022 Report Share Posted October 14, 2022 13 hours ago, HarryF said: Thank you tho. I had the same question. well hell, welcome to 2022. Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
