honolulublue Posted April 5, 2012 Author Report Share Posted April 5, 2012 so today i conclude that red wire from the car harness gave me power to the deck but when i had both yellow and red from the deck hooked to yellow coming from the car harness it would not power on...if i ran a wire from the battery positive to the deck receiver yellow would that work? Link to comment Share on other sites More sharing options...
uhoh_45 Posted April 5, 2012 Report Share Posted April 5, 2012 you need a switched power source- get a fuse tap and tap into the ignition fuse and run wire from that to your deck and should be good R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
Hotdog Posted April 5, 2012 Report Share Posted April 5, 2012 Or grab your multi-meter and start testing wires for ignition source. With my Daughters car 2000 Chevy Monte Carlo the harness that Crutchfield said I need for my car did not even match up. It is one of the amped factory systems.So I just cut the factory wires long enough so I can take it back to stock if needed. I had every wire I needed in the dash opening for the radio except for the ignition wire. After getting my multi-meter out and testing wires I found that there is a wire that goes to the hazzard button that is 12v switched wire and I tied into that. (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764 Link to comment Share on other sites More sharing options...
honolulublue Posted April 5, 2012 Author Report Share Posted April 5, 2012 boom boom clap Link to comment Share on other sites More sharing options...
ham4864 Posted April 5, 2012 Report Share Posted April 5, 2012 its not hard at all Find a switched 12volt. a constant 12 volts and ground that MOFO. multi meters are your friend. I bet you will figure it out if you sit down and think about it for a second. Some times the aftermarket radio harness can be made wrong.That harness may fit other years and types of GM cars but the pin out may be different. 2009 bmw 5 series Head Unit Stock Amplifier-JL Audio JX 360/4 Processor- Audiocontrol LC6 Link to comment Share on other sites More sharing options...
n8ball2013 Posted April 5, 2012 Report Share Posted April 5, 2012 If you cant figure this out you need to take it to someone. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
t-money Posted April 6, 2012 Report Share Posted April 6, 2012 if you want RAP (Retained Accesory Power) they are usually n the driver kick and will stay powered up until the door is opened. just like the factory does. and they are usually a 12 gauge wire that it yellow, blue or white. test to make sure first. 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056 Link to comment Share on other sites More sharing options...
ALPINE408 Posted April 6, 2012 Report Share Posted April 6, 2012 If you cant figure this out you need to take it to someone. I agree this basic audio 101 this should be the first thing you Learn Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
