Well, i wanna take a shot as designing a 4th order, i have absolutely no experience and have no idea where to start....so any help would be appreciated, once i get the basics i can start designing and whatnot from there. but before that, can i make a 4 th order for 2 skar 12's in a 14x36x26in space?give or take an inch on all those measurements, those are just my safe measurements.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
those dims equal to 6.11 cubes not counting displacement of subs....I am not sure of reqs. for skar 12s or 4th order guidelines for sealed and ported sections
looks like you could do a 2:1 ratio if thats within the specs for the skar 12s and meets guidelines for 4th orders
i would check with 412CVX he designs 4th for people all the time..and could hook you up with something
Edited by stroupe79
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
give them .75 -1 cube a piece on the sealed side. use the rest as the ported side. make a lot of port and tune it to about 50-55
the worst that can happen is it fails miserably so give it a try. you will have to build the box in that trunk though.
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
I already planned on building this box in the trunk, have u had any experience with skar's or 4th orders though?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
i'm with punk here with those specs
as far as box ideas
R.I.P!
(Nov-29-2009)
92 explorer
current build
Me neither, but its interested me for a while, guess its time to get back on sketchup and start designing, ill be back with box designs soon enough. Thanks for the input everyone
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Robin from BHE built Malibooms car. Had 8 skar 12's in a 4th doing 54s, at like 30hz, off a 3500.
Edited by OBI
no idea how the skars will like 4th orders
Wellll...guess I'll find out soon enough ;D
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Well, it'll only be these 2 12's off a single 1500, for now that is.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
  • Who's Online   0 Members, 0 Anonymous, 2057 Guests (See full list)
