Well, it'll only be these 2 12's off a single 1500, for now that is.
dont expect numbers in that car
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
I just want it to be louder than it is in my current box, i'm not looking for numbers at all, just something that continues killing the lows, but has a wider response range than my current box (first one i ever built, believe me....it is shitttt).
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
Would anyone happen to know why it echoes inside my car when someone speaks or when any noise happens inside the car, there's an echo...why?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
if you want a ground pounder and dont care about numbers tune low.. like 42-45 hz and have lots of port.
17-20 per.
my old 4th peaked at 33 hz. it was two 12s on 2k and it was great. didnt play much over 42 hz though.
if your feeling froggy go between 20-25 per on port area. but unless your design is good and know you wont have unloading issues id stay 20 and below
Edited by D-train-13k
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
17-20 per.
A ground pounder with simply 2 12's you sayyy. Haa, no, that's too broad of a spectrum for me, i dont listen to all songs with low ass bass, if so, id sure as hell tune lower...honestly, i was devise away to make the port swappable so i can try out what the different port tunings sound like on it and in my car without constantly having to destroy the box.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
17-20 per.
just used two sided foam tape for an adjustable removable port
you can do whatever port you want. doesnt need to be external. you cann do an internal port that can be removed
17-20 per.
Thanks man, this helped out a ton, i feel as if an external port would be easier to adjust, remove, and swap out...but i wouldn't be able to fold my back seat up then :/ going in 2000 mustang (trunk is a pain in the fuckin asssssss to work in).
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
if you can just make a box with an external port that is removable and try some different tuning . figure out what you like best and then make a real box with that tuning in mind.
sounds like a plan, bout to get on box designs and ill post em once i have atleast 1 :D
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
  • Who's Online   0 Members, 0 Anonymous, 1758 Guests (See full list)
