SSA ZCON 12 D2
Just noticed this...but on the website: http://www.soundsolutionsaudio.com/store/products/ZCON%252d12-D2-%E2%80%93-Sound-Solutions-Audio-12%22-2250W-Dual-2%252dOhm-ZCON-Series-Subwoofer.html
It says that the dual 2 option has 1.4/coil. Which means I'll be wiring it down to a 0.7 ohm load? Will my amp be seeing a 0.7 ohm load then? Originally thought that the dual 2 was actually 2 ohms per coil, but that's what I get for not reading I suppose.
ive seen alotta subs like that....what amp are you running?
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
meh u should be ok... just make sure you keep ur voltage up youll be fine
power: dd m4
Just noticed this...but on the website: http://www.soundsolu...-Subwoofer.html
Thats the DC resistance of the coil not the impedance which is 1 or 2 ohm.
  • Who's Online   0 Members, 0 Anonymous, 1000 Guests (See full list)
