Vids,Updates,4 SKAR VVX 15's,Toolmaker Duals,Kids Hair Trick,Windshield Flex
build progress, got the "stripper pole" internal brace mounted, ports fiber glassed up for strength and are curing will let it all set and try to get done totally Sunday
William - Metter,Ga. Dad, Self Installer/Fabricator & Repair Tech, Weightlifter, Motivator,
Team SKAR Audio Captain, Team Deadly Hertz Georgia Leader
99 Toyota 4Runner SR5, "Rolling Thunder"
Daily Driven, No Wall, C-Pillar Build, BASS LIFE!
2K16 SBN MECA Park and Pound DB3 Champion
2K16 SBN ISPLL Real SPL Class F Champion
Second Skin Damplifier Pro, Kenwood eXcelon KDC X498, Clarion EQ, Knukonceptz RCA's
The Big 3, Sky High Car Audio OFC & Kicker Hyperflex Silver Tinned 1/0 Gauge
Singer 340a Alt, Northstar NSB-AGM31, SMSAGM480, 12 NessCaps Super Caps
Rockford Fosgate 3Sixty Line Driver, The Oval Port Tuned To 31 Hz, CNC Machined
4 SKAR ZVXv2 D2 15's, 2 SKAR SK-4500.1's, 4 SKAR PAX 6.5's, 2 SKAR LP-80.4's
MEMBER OF THE YEAR 2013
If you don't have any haters, get some, best motivation there is...
That is cool my friend. But that is gonna have to be one short stripper...lol
she's a midget LMAO
Just a quick question? You did glue those flanges on correct? I ask, because I figured it would be more ideal to tape them on for testing (gorilla tape) until you found what you liked best, but either way im sure it will turn out AWSOME, time to pick up a skar 4500 :)
Good job by going with the precision ports, they make a huge difference
Don't mean to be negative will but why 4 aeros???? I think its too many man
The 4 aeros are 6inches internal diameter each. That is 28in^2 of moving mass per port. The enclosure is 9.8ft^3 of internal volume after all displacements. This gives us a ratio of 11.4in^2 of moving mass per ft^3 of internal volume. This is a very ideal ratio for a daily driver system. It gives a great balance between port gain, and musicality. It will still get plenty loud, and the subs will also play further below port without unloading.
The majority of box builders will usually build at 14in^2 per cube as a minimum, then upwards of 18-20in^2 to get more output for the meter. Once you do the math, its actually not as much port area as it seems.
Just seemed like too much for me since im used to building with a lot of cone area and we used 4 of these for 8 15" setup and 5 of these for 12 15'' setup.
Stripper pole looks nice Box looks solid too nice job
Bassaholics Audio
Custom Enclosure Designs
Custom Built Subwoofers tailored to specific enclosures
For more info
Email: [email protected]
updates
2x4's more bracing....
carriage bolts for the "stripper pole"
got glue for the top layer....
rounding corners
sanding bondo
ready to spray...
sprayed, done!
  • Who's Online   1 Member, 0 Anonymous, 803 Guests (See full list)
