Amp popping into protect.
evermaxx
Friends amp pops into protect, sony xplode 700watt with 1 12" Audiobaun SE
Funny thing is, he can play it with car on ACC and it bangs, but as soon as we go for a drive turn it up over 31/40 i goes into protect.
with car off, he can go fully. Thoughts? Yes I know check grounds and everything, and I know its bad to play with car off, it was just to test it for ~45 seconds.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Maybe to much power going to it too quick:/ try setting the gain down see what happens see if you can turn it up louder
that wouldn't make sense. the amp will pull as much power as it needs. the alt cant give it like 150a of power when it only draws 60, for example.
Edited by Kranny
Are you clipping?
What's the ohm load on the amp?
What sort of voltage are you getting at the amp when it goes into protect?
Are you clipping?
this.
also check your grounds, and check them again.. what size wire is the power and ground wire? where are you grounded, where is the amps location in the vehicle.
how hot is it in the car?
is there any airflow to the amp when your driving?
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
Are you clipping?
Amp was set by ear, he doesn't have tools to do it, but its not set crazy I know.
Not sure, 1ohm I believe?
On dash it's still steady. Before this set up he had a 1500 audiopipe and you could see the volt gague on dash move, so if the voltage was going down we could see it.
Are you clipping?
this.
Not sure, we've tried windows down, and A/C
Its behind the seat in an SUV.. amp is hot to touch after some time.
Team Subsonic Lows
My guess would be voltage too low with the car on which is why it's going into protect.
possibly bad alt?
^^^Check the alt first...what kind of batts are you running?
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
