http://www.audioque....1204_p_150.html
saying it only goes up to 5khz?
Specifications Model AQ120.4 Dimensions 15.75" x 9" Input Sensitivity 8V~0.2V Low Pass Filter 50Hz ~ 5kHz High Pass Filter 20Hz ~ 5kHz Crossover HPF/FULL/LP-BP Remote Gain Control Included Clipping Display Led Yes Signal to Noise Ratio 105dB Damping Factor 200 < Bass Boost @45Hz 0~18dB External Fuse Rating 40A x 2 pcs 4 ohm power @ 14V 120Wx4 2 ohm power @ 14V 170Wx4 4 ohm mono power @ 14V 340Wx2 Power and Ground Inputs 4ga
Edited by D-train-13k
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
Thats not low.
Highpass means highs pass from that point and up.
So.... Whats the problem?
Cheap x over on the amp if its a problem run fullrange and get a better external xover
Nvm I'm wrong thanks ray
Edited by Team Bassick (ALPINE)
Thats not low.
Ohhhhh. well im glad you cleared that up. cause im not really familiar with mids and highs and crossover points.
thanks
Here's an example of a high pass fail.
See if you can spot the problem.
lol
#teamihop
Two 12 inch DC XL's
Carbon Fiber Cap
Stetsom 7k
Shell of box / baffle built by me
Port / sealing the box by John Hone
Fuck midrange
Alpine-9886
http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/
price has no influence on how something sounds
I told him to move the fucking port.
they see me hoppin they stoppin they can't believe im so white and dirty
It looks like you got so drunk, that someone came up and stole your leg.
Same as lpf.
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
50 hz ist a mid bass freq? lol
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
LPF filters out everthing above that point, meaning if you set it at say 80hz, it will not play 81hz+
HPF filters out everything below that point, meaning if you set it at say 300hz, it will not play 299hz and down
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
i thought at those point the octaves slope off... not stop
