I'm upgrading my wiring plus its "messy" right now.
Here is my diagram, tell me if I need to add fuses or whatever.
All wiring will be 2/0 prene flex welding cable except to amps I'll be using 1/0
ANL fuses will be 200 or 250
Batteries: Shuriken BT-35, and 2 bt-20's
The two squares behind the skar amp are distribution blocks made out of aluminum.
Edited by HunterJohnson
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
well in theory you should have your postiive to your alt fused. both ends fo your front to back fused.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
If you're running a separate ground wire to the rear, then make sure the body of the alternator is well connected to that wire.
Or that the alternator has a clean connection to its mounting bracket and then ground your battery to the chassis/engine.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
What do you mean both ends of your front to back fused? Are you saying the pos and neg from the front battery fused?
It's a stock alt, I know HO alts have grounds on the back but does my stock one have a ground aswell.
here is my revised drawing with an ANL fuse from pos of front to pos of rear batteries.
Scion tC SQ Build
because if there is a short in the middle of the wire you need to protect both batteries. the front fuse blowing without a back fuse means that your back batteries dump all their power as a direct short. then you have a place to cook your marshmallows.
Stock alts are grounded through the bracket/engine.
Make sure you have another run from your front battery ground to the alt bracket/engine.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
Thanks didnt know a wire could short in the middle!! Then again I just started reading and understanding electrical/wiring
cool, I did the big 3, but when I learned that grounding to the frame is basically using the car's frame as a wire to ground it back to the battery I decided I wanted to just do a direct run from the neg in the front to the neg in the back.
I'm calculating all the costs as I speak (type) and picking up some welding 2/0 on wednesday hopefully!
Scion tC SQ Build
  • Who's Online   0 Members, 0 Anonymous, 1415 Guests (See full list)
