Would this be good box for an HDC3 15?
'01 Honda Accord EX 4 Cyl4/18/13
Started new build
Headunit: JVC kdx250bt
Sub Amp: Hifonics Hifi 2000d
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Wire: Knu 1/0 and 4awg
Big3:
No. Net box space too big and port area/net cubic feet too small. Could easily fix this by adjusting either width or depth and making either smaller.
EDIT: You want somewhere around 16 square inches of port area per net cubic foot though. So if you reduce the depth/width of box to make it around suggested specs for that 15 (I don't personally know) and you still haven't hit that number then try changing the port width to 3.5 or 4 maybe.
Edited by iChrisTucker
So I'm on the right track than i suppose? just a few adjustments.
Started new build
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Big3:
Alright so I changed my width to 25 giving me exactly 4 cubes after displacement and port width is now 4.2 and length is 23. Port area per foot is now 16.27^2.
Edited by blcrocker
Started new build
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Big3:
And your tuning is 37.14Hz, for a port/sub front or back you are good now, you can go up to 4.5 cubes net if you wanted.
