banginHOE Posted February 2, 2013 Author Report Posted February 2, 2013 the connectors are from electricdirect.com They are called water tight fittings. 8 SSA EVIL 15's 4 CRESCENDO 5500'S 2 SINGER HAIRPIN'S 21 XS POWER D1600'S ALL MCLAREN AUDIO MID'S AND TWEETERS 1 TARAMPS HD4000, 1 TARAMPS HD800 SEX!
Fosgatefeind Posted February 2, 2013 Report Posted February 2, 2013 the connectors are from electricdirect.com They are called water tight fittings. Link? I couldn't find that site on google Buildlog: http://www.stevemeadedesigns.com/board/topic/146515-2007-monte-carlo-ls-build-new-plans-with-dc-audio/ TEAM DC AUDIO www.Dcsoundlab.com
banginHOE Posted February 2, 2013 Author Report Posted February 2, 2013 the connectors are from electricdirect.com They are called water tight fittings. Link? I couldn't find that site on google Give me a min. We are building a 4th order wall in a 2 door blazer right now lol. 8 SSA EVIL 15's 4 CRESCENDO 5500'S 2 SINGER HAIRPIN'S 21 XS POWER D1600'S ALL MCLAREN AUDIO MID'S AND TWEETERS 1 TARAMPS HD4000, 1 TARAMPS HD800 SEX!
banginHOE Posted February 2, 2013 Author Report Posted February 2, 2013 I'm pretty sure the last 2 Tahoe styles are both 49" wide. Can you put up pics of what the wire runs look like under your truck? I'm debating on either doing what you did or adding grommets to the firewall and under the carpet going back. 8 SSA EVIL 15's 4 CRESCENDO 5500'S 2 SINGER HAIRPIN'S 21 XS POWER D1600'S ALL MCLAREN AUDIO MID'S AND TWEETERS 1 TARAMPS HD4000, 1 TARAMPS HD800 SEX!
banginHOE Posted February 2, 2013 Author Report Posted February 2, 2013 1st port is 35hz. Still need to hit it with a round over 8 SSA EVIL 15's 4 CRESCENDO 5500'S 2 SINGER HAIRPIN'S 21 XS POWER D1600'S ALL MCLAREN AUDIO MID'S AND TWEETERS 1 TARAMPS HD4000, 1 TARAMPS HD800 SEX!
flwatersaver Posted February 3, 2013 Report Posted February 3, 2013 Nylon Dome Strain Relief Connectors Much cheaper than the other places that were listed. http://www.elecdirect.com/product/01becf5c-abf9-4ce2-b245-06ccc3419c74.aspx Don't forget to add the nuts to put them on.. http://www.elecdirect.com/product/c7c40d8c-2c07-4be6-8e0d-5eef0b46470c.aspx Put in order2 at check out for a discount My selling FeedbackBuild log - Blazer C pillar wall, Two DC Audio 3.5k'sTEAM PSI
Hunters21w Posted February 3, 2013 Report Posted February 3, 2013 How bout overall dims? Looks like 49w.Yes it is 49" wide. Which kind of sucked because the birch sheets are only 48" wide so there was a ton of wasted wood. So overall it is 49 wide 23.75 tall and 32 deep iirc. I think lol. It is right at 14 cubes after port , sub displacement and bracing. I kept it that height so I can still do lightweight bass boxing. Box and everything attached to it has to be under 25" and with this it puts me at 24.75 so I'm good to go. Also ordered metal to make bus bars. Just need to drill and tap them. All amps are going under the back seat , 2 5.0's on one side and 2 175.4's on the other all stacked up. Nice, yea I can't go over 21.75" if I rememer correctly or else I will be considered a wall in dbdrag. The other dims work for me though so if it comes out nice I might give it a try. I hate that sheets come 48" wide too lol. 06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
banginHOE Posted February 3, 2013 Author Report Posted February 3, 2013 How bout overall dims? Looks like 49w.Yes it is 49" wide. Which kind of sucked because the birch sheets are only 48" wide so there was a ton of wasted wood. So overall it is 49 wide 23.75 tall and 32 deep iirc. I think lol. It is right at 14 cubes after port , sub displacement and bracing. I kept it that height so I can still do lightweight bass boxing. Box and everything attached to it has to be under 25" and with this it puts me at 24.75 so I'm good to go. Also ordered metal to make bus bars. Just need to drill and tap them. All amps are going under the back seat , 2 5.0's on one side and 2 175.4's on the other all stacked up.Nice, yea I can't go over 21.75" if I rememer correctly or else I will be considered a wall in dbdrag. The other dims work for me though so if it comes out nice I might give it a try. I hate that sheets come 48" wide too lol. You might want to look into that. I thought db drag rule was 30" now. 8 SSA EVIL 15's 4 CRESCENDO 5500'S 2 SINGER HAIRPIN'S 21 XS POWER D1600'S ALL MCLAREN AUDIO MID'S AND TWEETERS 1 TARAMPS HD4000, 1 TARAMPS HD800 SEX!
vetkilr01 Posted February 3, 2013 Report Posted February 3, 2013 Dang wish I was by Jacksonville, would of had you build me some stuff
Hunters21w Posted February 3, 2013 Report Posted February 3, 2013 Pretty sure it's 13" from lowest spot on headliner. 06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
