sorry mate i dont know what clamp means :s i googled clamping it measures how much rms ur amp pushes well does it matter if the amp is cea 2006 ??
That's why I said you can't measure with a DMM first, it's not all that accurate, second it doesn't detect distortion, or clipping. CEA compliant basicly means it pushes what it says it does.. at the volts it was tested at.
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
You're right and wrong. Of course gains can be set with a DMM, but you will never be able to see clipping that way. The truest way is with a scope of some kind.
put them in a 4th order or horn, problem solved.
Hammerdown... 1%
And how do you know when you're distorting? It's a simple fundamental property you're overlooking. Just because you don't hear it, does not mean you're not. Clipping at 38hz is not the same as clipping at a higher frequency. So like I said, you can set your gains, but you will not detect clipping with that method. Which is the whole point in setting gains correctly.
This...is exactly what I would expect you to say, lol.
  • Who's Online   0 Members, 0 Anonymous, 1451 Guests (See full list)
