profundus-sanus Posted April 11, 2012 Report Share Posted April 11, 2012 its all a compromise. make sure you ahve a voltage gauge up front thats wired right before your amps. its a safe bet that your amps will be 70-75% efficient at 1 ohm full bore.. so with 4 amps your looking at 1500 amps draw. 2 300 amp alts bring you down to 900 amps draw.. which you'll need at least 7-8 group 31 batts you should have at least 2 + and 2- 1/0 runs per alt if your running 300a units. Quote Link to comment Share on other sites More sharing options...
AA98hoe Posted April 11, 2012 Report Share Posted April 11, 2012 You think only 1500amps? I say 2000amps..I had the ddm4s very similiar to aq3500 and the pulled close to 1000 amps Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
profundus-sanus Posted April 11, 2012 Report Share Posted April 11, 2012 You think only 1500amps? I say 2000amps..I had the ddm4s very similiar to aq3500 and the pulled close to 1000 amps 1000 amps a piece? sounds like clipping to me haha. 3500/ 12.8= 273 amps 273 / .7 = 390 (after a less than optimistic efficiency estimate) 390x 4 = 1500 amps Quote Link to comment Share on other sites More sharing options...
Soapbox Posted April 11, 2012 Report Share Posted April 11, 2012 (edited) Profundus the results are actual clamped results Ray posted. It is what is is. It was clamped for the pair therefore if you were to double the number of amps it would result in 2000 amps of draw. But as you know it's all a balancing act depending upon install electrical base and box rise. Knowing Ray it was probably clipped a little definitely not a full clip. Edited April 11, 2012 by Soapbox Quote TEAM FLEX ISSUES, TEAM DC AUDIO 2010 California State Finals Champion MECA AS2 2011 California State Champion Meca S2 2011 California State Record holder Meca S2 2012 Meca Mod 4 class 152.5 and rising Link to comment Share on other sites More sharing options...
AA98hoe Posted April 11, 2012 Report Share Posted April 11, 2012 Thanks soapbox.. and yea I clamped 12k out of 2 m4s..with a slight clip.. so they were underated..ami had similiar results from the aqs.. Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
medley123 Posted April 11, 2012 Report Share Posted April 11, 2012 As much as you may want to go big or go home, you're better off building something and then adding to it, in my opinion. Then again, I don't know what kind of experience you have with your previous installs. Quote 2006 Ford EscapeHead Unit: Kenwood KDC 352Subs: (3) 15" DC XL 15s with PSI recones, 1.4 ohm coilsSub amp: DD Audio M4 (Black Version)Door Speakers: (2) Crossfire 10s, (2) Hertz Coax.Mid/highs amp: Rockford Fosgate P500-4 Electrical:XS D3400 under the hood(3) XS XP3000s in the back2 runs of KnuKonceptz OFC 0 Gauge ran to the back (1 pos, 1 neg)Excessive Amperage 300 amp alt (FINALLY!) Link to comment Share on other sites More sharing options...
Chaosgrunt Posted April 11, 2012 Author Report Share Posted April 11, 2012 As much as you may want to go big or go home, you're better off building something and then adding to it, in my opinion. Then again, I don't know what kind of experience you have with your previous installs. Not much other than little 2kw installs TBH. Done lots of research but i understand that research and doing are 2 different things. And yeah, i am going to build a wall with 1 aq3500 then start adding to it slowly. Sorry for the confusion, didnt mean to say "Im gonna buy 4 amps all at one time and install them", just meant when its all said and done, i want to have 4. But since i have decided to wall the stang, it will only have 3 3500's, not 4. So Realistically powering 3 wouldnt be too hard. Lets hope Dom can pull out some awesome alternator bracket making skills here. Wont be easy making a dual alternator bracket let alone the 3-4 alternator bracket i truly want. Quote Link to comment Share on other sites More sharing options...
banginHOE Posted April 12, 2012 Report Share Posted April 12, 2012 Overpower subs and power all the time?.... bro id stick with 1 or maybe 2 amps...no way are you ready for 4. I have 3 alts 6 batterys and 10 runs of 0g and its not enough at idle to support 15k..2 alts and 20 batterys mite get you minimum voltage drop..but I doubt you have funds or space for that...I have over 5k in my electrical ^^^^^^ THIS !!!!!!!!!!!!!!!!!!!!! Electrical shit is expensive Quote 8 SSA EVIL 15's 4 CRESCENDO 5500'S 2 SINGER HAIRPIN'S 21 XS POWER D1600'S ALL MCLAREN AUDIO MID'S AND TWEETERS 1 TARAMPS HD4000, 1 TARAMPS HD800 SEX! Link to comment Share on other sites More sharing options...
