its what i used to clean before i layed shit down- it evaporates fast too which is nice and it is relatively cheap
R.I.P!
(Nov-29-2009)
92 explorer
current build
Yeah. It sticks so well you can almost just clean it with a dry rag. Lol. But I use rubbing alcohol as well. Works fine for me.
scrape off all excess stuff with a razor blade and then wipe down with alcohol
also if you use a heatgun no matter the brand of deadener it always goes on easier/comforms better and sticks better too
Yep yep, that will work just fine. The main thing is to avoid using any citrus based cleaners as they tend to leave an oily residue.
And it's best to install the product at or around room temp.
Have a question about Second Skin? E-Mail me!
Turn on gun
Heat product
Turn off gun (safety first)
Stick product to car
Repeat
"Cheap, good or fast. You can only pick two out of three."
"Have money? Love story! No money? I'm sorry."
:good: That's the procedure I used; worked great and it was about 50ºF outside. I was in the garage though. Haven't had any issues in the couple of weeks its been on...
  • Who's Online   0 Members, 0 Anonymous, 928 Guests (See full list)
