MrFree Posted April 11, 2012 Report Posted April 11, 2012 Hello everyone; I have done a couple search's and I wasn't able to find what I was looking for so I figured I would make a thread. Could anyone tell me how to wire up a Big 3 with 2 alts.Do I just run the alts together and run one alt to the battery? R.I.P...99'Dodge Grand Caravan 03 Lancer Oz Big 3 HU-JVC KD-530 RCA's-rockerfosgate 41/2 inch Infinity mids Subs-(12's)2 Orion xtr124 Amp-Coustic600se battery-2 x stock, 1x Shuriken SK-BT20 Box-L-ported 3.562cubes@35Hz miscellaneous-stinger volt-meter, gain nob, (coming soon bass pro,eq,line drive) I dont have flex yet but damn I sound good,(coming soon....flex) Check out my HHR install Everything I install or build here:http://s1160.photobu...s/q485/MrBfree/ Also video's of my Car with the new box.http://www.youtube.c...lentGyge/videos
memphisBred Posted April 11, 2012 Report Posted April 11, 2012 I'd run a power and ground from each alt to your front battery. SMD Super Seller/Buyer Audison----Hertz----Rainbow
MrFree Posted April 11, 2012 Author Report Posted April 11, 2012 this is going to sound stupid but I didnt think they had a ground. So dont connect the alts, just wire them both to the battery R.I.P...99'Dodge Grand Caravan 03 Lancer Oz Big 3 HU-JVC KD-530 RCA's-rockerfosgate 41/2 inch Infinity mids Subs-(12's)2 Orion xtr124 Amp-Coustic600se battery-2 x stock, 1x Shuriken SK-BT20 Box-L-ported 3.562cubes@35Hz miscellaneous-stinger volt-meter, gain nob, (coming soon bass pro,eq,line drive) I dont have flex yet but damn I sound good,(coming soon....flex) Check out my HHR install Everything I install or build here:http://s1160.photobu...s/q485/MrBfree/ Also video's of my Car with the new box.http://www.youtube.c...lentGyge/videos
memphisBred Posted April 11, 2012 Report Posted April 11, 2012 I'm guessing your alts will have two to three bolts holding them to the bracket. Run a 1/0 wire or two, from your battery negative post, to one of those bolts, for an engine block ground(s). I'd prefer a 1/0 wire to each alt. On the alt ground, make sure where the alt is bolted down to the engine block is free of paint/dirt/etc(bare metal). SMD Super Seller/Buyer Audison----Hertz----Rainbow
MrFree Posted April 12, 2012 Author Report Posted April 12, 2012 Thank you sir. R.I.P...99'Dodge Grand Caravan 03 Lancer Oz Big 3 HU-JVC KD-530 RCA's-rockerfosgate 41/2 inch Infinity mids Subs-(12's)2 Orion xtr124 Amp-Coustic600se battery-2 x stock, 1x Shuriken SK-BT20 Box-L-ported 3.562cubes@35Hz miscellaneous-stinger volt-meter, gain nob, (coming soon bass pro,eq,line drive) I dont have flex yet but damn I sound good,(coming soon....flex) Check out my HHR install Everything I install or build here:http://s1160.photobu...s/q485/MrBfree/ Also video's of my Car with the new box.http://www.youtube.c...lentGyge/videos
MECHMAN Posted April 12, 2012 Report Posted April 12, 2012 I'm guessing your alts will have two to three bolts holding them to the bracket. Run a 1/0 wire or two, from your battery negative post, to one of those bolts, for an engine block ground(s). I'd prefer a 1/0 wire to each alt. On the alt ground, make sure where the alt is bolted down to the engine block is free of paint/dirt/etc(bare metal). Good advice. Running the ground directly from the alternators to the battery negative is always the best way to do this. 1-888-MECHMAN www.Mechman.com [email protected]
