Mechman Alternators
need help guys wiring up my new mechmans
Our units have the GM plug out the back? If so, just match the wires on the plugs, and connect as I said above and it will work fine provided that they are set up from our shop for external regulator use.
Edited by MECHMAN
so you have mechman alts
someone elses harnesses.
Why not just ask mechman to price you a harness. I bet that would solve the aggravation of trying to patch something together. it may cost a little more but its probably better to know its goign to work.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Beautiful alts...that is the exact setup I want to change too.....
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
This may be the best solution unless pinning that plug properly gets things working. I don't understand why DC won't help you, but we will do what we can to get this straight for you.
and people say im a dick and not helpful. ha
  • Like (+1 Rep) 4
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 399 Guests (See full list)
