MRLOVETHATBASS Posted April 15, 2012 Report Share Posted April 15, 2012 i running three 15"s , subs up port back and my aero are like 10" from the back wall. is that enough room for the aero to breath good for the bas Link to comment Share on other sites More sharing options...
john253a Posted April 15, 2012 Report Share Posted April 15, 2012 depends on the size of the port rule of thumb is diameter of port = distance from back wall Link to comment Share on other sites More sharing options...
MRLOVETHATBASS Posted April 15, 2012 Author Report Share Posted April 15, 2012 depends on the size of the port rule of thumb is diameter of port = distance from back wall well i have two 8" aero ports, and from my calculations they will be 10.5"s from the back wall, is that enough????? Link to comment Share on other sites More sharing options...
getlocivic Posted April 15, 2012 Report Share Posted April 15, 2012 ^^ more than enough if you only have a 8" aero you only got to be 8" away from the back wall otherwise youll choke the port out 4" aero.. 4" away from wall 6" aero..6" away etc etc Link to comment Share on other sites More sharing options...
MRLOVETHATBASS Posted April 15, 2012 Author Report Share Posted April 15, 2012 ^^ more than enough if you only have a 8" aero you only got to be 8" away from the back wall otherwise youll choke the port out 4" aero.. 4" away from wall 6" aero..6" away etc etc thank to both of you guys i was kinda worried it wouldnt breath, now wat about the sub, how far does it have to be in the away from the subwoofer. like my box is 20.5H, the subs have a depth of 10"inches Link to comment Share on other sites More sharing options...
