Hi I have a 2011 camaro and I installed a DC 270 amp alternator for my 2 amps. Problem is the computer controls the voltage that the alternator puts out. When I start the car and drive the first 10 min or so i get 14.3 volts then it drops to 12.3 to 12.5 for a while then it goes back up to 14.3 . It is so the car saves gas and shit like that. Anyone no of a way to keep the voltage up higher? I also have 3 XS power battery's in the trunk.Thanks
talk to mechman or dc (this first...since you got the alt from them)
edit: probably every option you do will void the warranty. im not 100% sure on this, but you will more than likely need to add a module in your car to bypass the pcm
Edited by Kranny
Turn your driving lights on, see how that works out
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
This, if I turn on my headlights on my '09 Equinox, my charge voltage climbs back up to 13.9ish. Not the auto headlights either, but the actual headlight position on the selector switch.
Not low beams or anything, just the one before that
Selector switch positions
Off
Blinker lights and tail lights- this one
Low beams and blinker lights and tail lights.
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
warranty is really important, see what you can come up with talk to the people who sold you the car check your warranty and all that good stuff, later on contact whomever sold you the alt and talk to them see what they can help you with.
build coming late April, early May
build log for 1 LVL 5 18" 87%ish done : http://www.stevemead...ab-dc-lvl-5-18/
1997 Dodge Ram 1500 Slt Laramie
Amplifier - AQ3500d.1
Sub - DC LVL 5 18"
Highs - (2x) Selenium ST-350 Super Tweeters 8ohm
Mids - Selenium 6" 200w midrange 6W4P (pair)
Mids/Highs Amp - MB Quart ONX4.125 1000watt 4 ch
Wiring - XP Flex 25' Red, 25' Black
Alternator - Mechman 270amp
Battery - XS power D3100, 1- Yellow top front
more to come...
I was going to post the exact same thing i have an 07 gmc yukon and the charging voltage is also regulated i think because it fluctuates from 12 to 14.
Is there a part that makes it a constant 14?
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
