4channel bridged to each voice coil??
Mikey Bates
lets say you have a 4 channel amp that puts out 50rms x 4 @ 4 ohms... 75 rms x 4 @ 2 ohms.....and bridged 150rms x 2 @ 4 ohms.
Can i take one bridged lead and run it to voice coil A on my sub (which is 4 ohms) and run the other to voice coil B on my sub (also 4 ohms)
That way each voice coil is getting 150rms from the amp, and the amp is getting a 4 ohm load from each voice coil.
yes, or no? does this work, is it a do, or don't?
sounds like itll work to me but with a 4 channel one side almost always has high or low pass an the other just has high pass....so dont know if yours does or not but if it does it might be an issue
http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187
JVC KD-R530 head unit
VVME INNO-D1500 sub amp
Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms
DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared :( )
they both have the same things, i just have to make sure i set them very, very, very close to the same haha otherwise it's gonna wanna push lets say 85hz and lower to one coil, and like 95 hz to the other if there off a little bit. ill do some testing (: just getting opinions
yes it can be done
yes you have to gain match
no i wouldn't do it
monoblocks are easier
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 1147 Guests (See full list)
