thats why i love em i have not seen any other sub that can take the abuse a Mayhem can take
X2!!!!!!
Current system:
Previous systems:
ok so im working with a 1996 ford ranger extedned can i have about 22" deep to play with and i dont want to go much higher then the back window with the enclosure if possiable could i place one behind each seat and place the port for the box in the center? so the air will be moved around the arm rest? would that work for the volume they need?
ill get more numbers up tonight when i have a chance to measure everything out right but i know i got 22 inches deep and right around 24 inches tall width im not sure on will update tonight when i get home
port and subs up port in the middle would be great for music
Would you put them in seperate chambers and do two 6inch areo ports in the center with like a baffle between them or just a baffle design box and one big port in the center?
