cole00c7r Posted April 20, 2012 Report Posted April 20, 2012 Hi i am very new to making enclosures and i want to build one that is 4 feet wide....i was thinking about putting 3 Rockford Fosgate P3's 2 ohm in it and i need help figuring out the depth and height of the enclosure. I also need a little advise and help deciding on port dimensions. Anything will help just need some advice. thanks I can have a max size of 4 feet by 2 and the rest I can base of tf the design MIDS-HIGHS 8-Rockford Fosgate Punch Pro 6.5's for now.... 2-Rockford Fosgate Punch Pro 8's 4-Rockford Fosgate Punch Pro 1'' Neodymium tweeters 2-Rockford Fosgate Punch Pro 10's AMPLIFIERS 4-Rockford Fosgate T2500-1bdCP 2-Rockford Fosgate T1000-4ad 1-Rockford Fosgate T800-4ad PROCESSING 1-Rockford Fosgate 3SIXTY.3 SUBWOOFERS 2-Rockford Fosgate T3S2 19's NEODYMIUM
Joe X Posted April 20, 2012 Report Posted April 20, 2012 Hmm..I wouldn't mind knowing what vehicle that box would be going into...
cole00c7r Posted April 20, 2012 Author Report Posted April 20, 2012 2002 escalade, have any advice? MIDS-HIGHS 8-Rockford Fosgate Punch Pro 6.5's for now.... 2-Rockford Fosgate Punch Pro 8's 4-Rockford Fosgate Punch Pro 1'' Neodymium tweeters 2-Rockford Fosgate Punch Pro 10's AMPLIFIERS 4-Rockford Fosgate T2500-1bdCP 2-Rockford Fosgate T1000-4ad 1-Rockford Fosgate T800-4ad PROCESSING 1-Rockford Fosgate 3SIXTY.3 SUBWOOFERS 2-Rockford Fosgate T3S2 19's NEODYMIUM
cole00c7r Posted April 20, 2012 Author Report Posted April 20, 2012 Hmm..I wouldn't mind knowing what vehicle that box would be going into... 2002 escalade , have any advice? MIDS-HIGHS 8-Rockford Fosgate Punch Pro 6.5's for now.... 2-Rockford Fosgate Punch Pro 8's 4-Rockford Fosgate Punch Pro 1'' Neodymium tweeters 2-Rockford Fosgate Punch Pro 10's AMPLIFIERS 4-Rockford Fosgate T2500-1bdCP 2-Rockford Fosgate T1000-4ad 1-Rockford Fosgate T800-4ad PROCESSING 1-Rockford Fosgate 3SIXTY.3 SUBWOOFERS 2-Rockford Fosgate T3S2 19's NEODYMIUM
GoonSquadSTL Posted April 20, 2012 Report Posted April 20, 2012 Hi i am very new to making enclosures and i want to build one that is 4 feet wide....i was thinking about putting 3 Rockford Fosgate P3's 2 ohm in it and i need help figuring out the depth and height of the enclosure. I also need a little advise and help deciding on port dimensions. Anything will help just need some advice. thanks I asked for help on here too, for my dimensions, first I would measure your max dimensions and put them on here so people could potential sketch you up a box design. ___________________________________________________________________________________ -1997 Oldsmobile Cutlass Supreme Coupe- -2 12'' Alpine Type R's- -Sony xPlode Head Unit- -Planet Audio AC2000.2 Amplifier- Anarchy Series 2-Channel Amplifier RMS Power Rating 2 ohms: 700 Watts x 2 chan. Bridged, 4 ohms: 1400 watts x 1 chan. ___________________________________________________________________________________
cole00c7r Posted April 20, 2012 Author Report Posted April 20, 2012 Hi i am very new to making enclosures and i want to build one that is 4 feet wide....i was thinking about putting 3 Rockford Fosgate P3's 2 ohm in it and i need help figuring out the depth and height of the enclosure. I also need a little advise and help deciding on port dimensions. Anything will help just need some advice. thanks I asked for help on here too, for my dimensions, first I would measure your max dimensions and put them on here so people could potential sketch you up a box design. ok I will add them to the top thanks MIDS-HIGHS 8-Rockford Fosgate Punch Pro 6.5's for now.... 2-Rockford Fosgate Punch Pro 8's 4-Rockford Fosgate Punch Pro 1'' Neodymium tweeters 2-Rockford Fosgate Punch Pro 10's AMPLIFIERS 4-Rockford Fosgate T2500-1bdCP 2-Rockford Fosgate T1000-4ad 1-Rockford Fosgate T800-4ad PROCESSING 1-Rockford Fosgate 3SIXTY.3 SUBWOOFERS 2-Rockford Fosgate T3S2 19's NEODYMIUM
