carshateme Posted April 20, 2012 Report Posted April 20, 2012 Okay I called Ohio Gen to get a price quote on an alternator for my car (Never got one, apparently their computers were down 2 days ago and he's struggling to get everyone's orders)...but we ended up talking for a bit, he started rambling how good his company is and such and then he told me this is the correct way to wire a system for proper charging of all batteries. Is this true or is he bullshitting? You'd put a bus bar on the back three batteries and then you'd put the positive from the starter battery on to the first battery and then you ground off your last battery. New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
Lbox88 Posted April 20, 2012 Report Posted April 20, 2012 That's right. Better would be to do a separate run from starter bat - to back bank -, but that'll work. UBL | Build Log
Team Bassick - Kimo Posted April 20, 2012 Report Posted April 20, 2012 Not completely Wrong but, for the most part it would work. What you need to understand is that in order for the alternator to charge it needs a complete circuit thus, the positive and ground wire. Now, personally I would run multiple runs back and forth depending on charging needs. However, just to charge the batteries the above diagram will do that but, it is not for optimal charging but if your current draws is not that demanding it will be fine. KIMO @teambassick http://www.teambassick.com
ham4864 Posted April 20, 2012 Report Posted April 20, 2012 true or you can use 4/0 to connect the batteries. and neg. battery to neg battery.You do it just like you do a amp.get it. also think about a battery isolator. 2009 bmw 5 series Head Unit Stock Amplifier-JL Audio JX 360/4 Processor- Audiocontrol LC6
carshateme Posted April 20, 2012 Author Report Posted April 20, 2012 Okay, for some strange reason I thought you'd want to run a wire from the alt to the back batteries as well..but he said that it'd be improper charging to the starter battery. So you'd run multiple positives from the starter battery to the back batteries? -Just trying to get things straight here before I get started. I'm going to be running 3,000rms through my vehicle on a OHIO GEN alternator or Singer alt. I haven't gotten a price quote from Ohio yet. New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
JMZNeal Posted April 21, 2012 Report Posted April 21, 2012 If you were running mult alts then you would run mult wires back to back bank but if just one alt then as long as the wire is big enough one will be just fine from alt to starter bat to back bank. And if your grounds are good to the frame or unibody then that diagram is good to go. just make sure ALL your contact points are clean and dielectric grease cuts down on corrosion mixing metals together like copper wire to brass to lead ect. I don't know about the max amperage a frame can ground but I don't think 300ish would be too much. Later if you add a second alt... run it straight back. Oh and if you can ground your alt to frame that is a good thing too. It's all about wire size vs the amperage you want to send down them. 3000w rms should = 300amps ish..... make sure your wires and connection points can handle that to the back bank from the alt and you'll be fine. JVC AVX-44 and 360.2 Subs: 2 RF T1 12s 1ohm mono off a RF T1500bdcp 80hz \/ in a 2.3cube 45hz slot port Mids: 2 O2 8's off a Punch 550.2 behind seat, 2 Image Cxs 6.5's and 2 ID XS 6x9s 80-3khz in doors on a T600.2 Highs: 2 ID CD.1 MH HLCD 8ohm off a RF 400.4 3khz /\
carshateme Posted April 23, 2012 Author Report Posted April 23, 2012 Alright, thanks. It's two separate amplifiers... ones a 2k rms amp and the other is a 4 channel 1k rms amp I believe...but I'll only be pushing 500rms New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
