Brand New Brutus BRZ 1700.1D in protection mode after.......
Recently purchased a Brutus BRZ 1700.1D..
Have it powering 2 Sundown SA 12" D2's wired at 2ohms. (never had a problem with any other amps wired at 2 ohm.)
It was playing fine yesterday at high volume and that amp pushes my subs really hard..Best ive had...ever..
Then today, as i start my car, the amp will turn on, and even with out playing any music, 20 seconds later, it goes into protection mode
Ive checked all my wiring.. I have 4 gauge all around. Does this amp require bigger ground and power wire?
This is my first "CEA-2006 Compliant" amp
2-gauge power and ground wiring is required for installation.
there is some VERY hard headed people out there. Anyone who says a DD-1 isnt necessary is also saying an O-scope isnt necessary. Anyone who says an O-scope IN THE MINIMUM isnt necessary, is a noob. Forget the DD-1 for a minute, any reputable installer will at LEAST use an O-scope. Those guys in that thread are clowns. Hard headed clowns.
double check your ground, double check and make sure you aren't wired at .5
EDIT: i thought i read 1200...you probably need larger gauge power wires.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
yeah i upgraded the entire system with 0 gauge wiring and it still does it, here and there.. I'll have to restart my car so my amp can stay on, and running...
going on the assumption that the amp isn't faulty, which it may very well be, first place i would check is your ground.
F150:
Stock :(
Processor: DSR1
could be a bad amp if you checked everything.
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
Agreed, most problems like that have to do with your ground, my amp does that sometimes cause my ground is shit....hopefully is just isn't a bigger problem.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
  • Who's Online   0 Members, 0 Anonymous, 1277 Guests (See full list)
