Rf Capacitors?
Hi, got a 1 farad capacitor rockford fisgate punch from my friend. I am wondering if it is better to sell it or install it. I'm running a very simple setup 4 gauge wire to an 800w pioneer amp to a jl audio sub. Would I notice any increase in performance? If not ill just sell it.
I am also going for sq not spl.
they did a review on a stinger cap in PAS mag, check it out
i love this sh--t man 1966 Ford Fairlane Pioneer prs 80, the big three, with 2 big azz agm batts, dual 270/200 amp alts , two 8'' mids and tweets in the kick( PPI phantom 600.2). two 10''s and tweets in the doors, two 10'' mids and tweets in the rear decK ( Lanar opti 500x2). 2 C2 Audio Threatcon 4 12s on a Crunch GP3000d. No crossover .
  • 1 month later...
It should help. I know I'll probably get slapped for this if its wrong, but I've always heard that you should have about 1 farad per 1000W of power. I'm currently running a small setup myself. have a 1000W Kenwood amp going to two Kicker C124's and I run a 1farad RF cap. It cleared up my headlight dimming in no time flat :)
Rowan University Electrical Engineering
LINK TO MY BUILDDDDD
Current Setup in my 00' Hyundai Accent:
Pioneer DEH-P6900UB
RE.6.5C AUDIO 500w 6.5" COMPONENT CAR SPEAKERS
Eclipse SE 6500 (6.5 coax in rear deck)
two Kicker C124's in a t-line tuned to 28.6Hz
Kenwood KAC-7204
US amps 1600.4 V2
Upcoming Build this summer:
T-Line enclosure for two C124's tuned to 28ish hz O_O
amp my speakers with a US amps 1600.4.
Second Skin Should be fun ^_^
  • 2 months later...
  • 3 weeks later...
Heres there 100 farad cap cap
Thanks for the explanation. I always wondered what caps actually did. I have a 4 farad cap and I always wondered why the RF one was more than mine I payed $90 for mine
Woofer:Fully loaded(3inch coil)15 inch Fi BL 4 cubic ft box tuned to 32hz
Bass Amp: Audioque 1200d(just purchased a Sundown Audio SAX 1200d)
Highs/Mids Amp: Alpine PDX 4.100
Door Speakers: Alpine Type R and S 6.5's
Vehicle: 2008 Mazda 6 stock alt and soon to be XS Power S1200 0gauge ran from batt to cap and 4 gauge to both amps
What size cap would I need? I'm running a RF P1000 and Alpine PDX 4.100. I have a cap I paid $90 for it's "4 farad" but it's not working for me. Could it be because I'm only running 4 gauge on each amp?
You really didn't give me much information to go off of . . .
- Your amps are obviously unregulated as they can produce more power with higher input voltage . . . maybe T3ks?
- What topology are they? (Class D?, bd?, A/B?) OR, what are their efficiency ratings?
- How much current at 14.4 volts are you paying Dom for?
Some simple math with your 3,000 watt Class D example at 14.4 VDC on sine waves would be:
3,000 / .75 = 4,000 watts Input required x 2 = 8,000 watts input
8,000 / 14.4 = 555 amps of current
Let's say your amps require 17 feet of power wire between them and the batteries and another 5 foot between them and the frame (chassis won't cut it here) for their grounds. To get 555 amps of current to your amps at 14.4 VDC, you'd need:
Big Wire:
- 1/0 AWG wire has .0001 ohms resistance per foot - 22 foot of it will have .0022 ohms of total resistance
- 555 amps through 22 foot of 1/0 . . . 555 x .0022 = 1.22 Volts drop in the cable alone
- 4 runs of 1/0 AWG . . . 555 x .00055 = .30 Volts drop in the wire - mo' better
BEEFY Alts:
- 300 amps at 14.7 volts . . . remember, we lost 3 tenths of a volt in our four runs of 1/0 AWG . . .
- 2 required
Now, if we add batteries, these need 7 to 10 amps of current each to allow charge to flow into them . . . I'm not seeing the benefit with the car running. But, if you wanted to jam this system with the key off then you'd need 'em for sure. Look at the AH rating on the battery you're shopping for. On music, these two amps would require roughly half of the current they require on sines . . . let's say these batteries had a 65 AH rating.
555 / 2 = 277.5 Amps
277.5 Amps / 65 AH = 4.3
So, you'd need 4 to 5 batteries to play this system wide open on music for ONE hour. After one hour, nominal battery voltage would be somewhere around 10.5 to 11 VDC.
And . . . these 4 batteries would require 40 amps of current to allow them to be charged with the vehicle running . . . better get Dom to up those alts to 350 amp models . . .
Ain't nuthin' free . . . Incidentally, this is a case where capacitance just can't cut it. The amount of capacitance a system this size would require would make it cost prohibitive, but if you could swing it, two of our 100 Farad caps of old would certainly help.
Now - where you're getting 16 volts DC you'll have to share . . .
  • 1 month later...
Whats the sizes on all the RF Caps they make Biggest to smallest?And How much does the Biggest one run?NOT msrp but bought @ a autherized dealer?
I have a 10 farad RF RFC10HB capacitor for sale for $200.00 shipped. The retail is $499.00. Hit me up.
LOL this thread is older than dirt but why we are at it I have a Lightning Audio/Rockford Fosgate CPCC1 50 Farad cap for sale and yes the way I used it, it was great and yes I know my shit.
I want $250 local or $285 shipped.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
  • 1 year later...
Well I am really just like.......uh......uh huh.......
I think i am going to put that 5 Farad back in my truck before i put the L7's in.......
When I was only running 1k rms I used a RF 10 farad hybrid cap. Very beneficial when you only need to maintain a higher/steadier voltage. I like this thread :)
06 GP GXP
Google Nexus 7 16gb
Rockford Fosgate 3SIXTY.3
*Electrical*
DC Power 320a HP
2 - Juicebox Bananas g31
Stinger SPP2250 rear
Kinetik HC1800 side of wall
Optima Red Top front
Monster Cable 1/0, 2 runs to rear
Monster Cable 1/0 Big 3
2-Rockford Fosgate T1652S's
Rockford Fosgate T400-4
Rockford Fosgate T40001bd (4693rms @1ohm)
4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's
15.2 cubes net tuned @34hz! Walled off
DBdrag official 151.6db @46hz
GXP Build log!:GP GXP Walled
Quality is the sign of a true enthusiast!
Refs: Link to leave more: http://www.stevemead...91#entry1603091
Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0)
Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
Anyone tested the new hybrid 10f cap out yet wondering if it actually does something unlike conventional caps?
2007 Scion Tc- T1500.1bdcp & t600.4, Three P3D212's Ported at 40hz, T2 6.5" Components, Rockford Marine 8" coax's. Kinetik khc1400 in back, Kicker 0 gauge
1999 Cherokee- Rockford Prime Amps 300.4 & 500.1,Big 3, Rockford 6.5"Comp.s and 6.5" 2ways, 2 12" P2's Ported basic winter beater
2002 Mustang Convt.-T1500.1bd & 400.4, 3 P3D210's IB, JBL components all the way around,Rockford 4 gauge, Big 3, Kinetik khc800 in back
  • Who's Online   0 Members, 0 Anonymous, 903 Guests (See full list)
