Saab 93 2001 (Hatch)
Amp: Rockford T1500bdcp
Daily box tuned to 35 hz, no intent for numbers
PWK Box
(1) DD 9518sc
Sealed on Dash 145.0 -- 42 hz
Kick Panel window down 146.1 --42 hz
Window down on dash
138.7 -- 25 hz
140.6 -- 28 hz
142.4 -- 30 hz
144.3 -- 35 hz
144.1 -- 40 hz
144.6 -- 41 hz
145.0 -- 42 hz
Port
150.8 -- 42 hz
So what do you guys think? It seems like im pretty flat across all the frequencies that the box was designed to play at. Im most impressed with the 28 hz score. Let me know if these scores are decent, good, or terrible.
Im thinking about doing some serious electrical upgrades. What kind of number do you think I could get out of this sub on a DD M3a?
Let me know guys! Thanks
Its hard to estimate numbers but i say shoot for your 150
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
any deadening?
PWK builds for flat response, your numbers reflect that. Did he build or just spec out for you?
2007 Pacifica
any deadening?
I built the box, but he drew up the plans. The flat response it just epic, it plays all notes with authority. I'd be happy to bump up all my numbers about 2 dbs after i switch amps or add one.
What do you guys think? add another T1500 and run both a 2 ohms or get an M3a and run it at 1 ohm
as far as deadening, its just on the front doors and back hatch, i will add more later.
deadening might get you 2 db's just sayin
2007 Pacifica
  • Who's Online   0 Members, 0 Anonymous, 964 Guests (See full list)
