i have that same amp. Yes each sub can get its own set of terminals , the terminals are interconnected inside the amp so you will still achieve the ohm load you are after
Alright thanks... how you like the amp? and what you have it pushing
Even though he said it ill say it also. Ive got two aq2200's and i love them so far, gonna wire them each down to .5 ohm, they should take it like champs. If your question relates to what pos and neg terminals on the amp you should wire your subs to, just wire your subs togather in the correct impedence and then just run your negatives to either negative on the amp, and your positive to either positive on the amp. Its a mono block amp, so its only got one channel, it has the 4 terminals just for easier wiring, basically the 2 negative terminals come together inside the amp, and the 2 positive terminals do the same. Sorry if i worded this in a confusing way.
Edited by ghostismyname
