Where do I go from here?
If you have the funding available get the alt rewound, It would be better to have a h/o but if your not gonna be able to do that for a while they do this. Also run a second battery in the cargo area, in place of the cap. This will give you the benefits of a distribution block and better electrical for your amps.
Two shops locally won't wind my alt, I've already inquired. I'll just save for the upgrade.
I did just pop a 100amp ANL underhood fuse though so I'm curious as what to replace it with. By my uneducated calculations it would be a 300amp fuse?
Optima Redtop Under Hood
Vmax CT800 Outback
Big6?(lol) 0/1 KnuKoncepts
2x 15" RF T1's in 7.7cuft @32hz
Audiopipe aqx3500.1d
Pioneer DEH-5000UB
I realize the cap isn't helping me much but I keep it for two main reasons, it shows instant voltage and it's an easy distribution point currently. Once I stabilize the voltage I will spend the time/money on actual distribution blocks and trash the cap. Thanks for the advice.
at this point the cap is literally just a power drainer. sell it for $40 and use the money to get a $20 volt meter to install in your line of sight on the dash and a $20 distro block.
You simply have a weak alt.
1)Upgrade to the 75A as fast as possible, then start saving for a H/O
2)Run a dedicated ground from the alt mounting bracket to (-) on the battery to (-) on the cap to (-) on the amps.
3)Consider trashing the cap.
-Drew
what do you mean when you say an H/O?
wooohoo!
-Acura RL 2005. Blue.
-Stinger Expert Roadkill..Trunk only
-(2) Skar VVX-12's D4 coils
-Dual slot ported to the left custom box tuned @ 32hz
-Audioque 1200D amplifier
A tribe called quest... ftw
Second battery > distribution block?
Vmax CT800 Outback
Pioneer DEH-5000UB
thanks kranny :)
wooohoo!
Haven't got any feedback on the fuse size yet. I have a spare 250amp fuse I'm just going to use that for now I suppose and I will probably run my full length ground tomorrow morning before work.
Vmax CT800 Outback
Pioneer DEH-5000UB
How many amps are both amplifiers pulling?
That's the size your front fuse should be.
You can use your battery as a dist block I believe. And then you have better voltage and still a dist block.
Double win
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
I don't understand how to figure the amperage both amps pull unless it's 1500watts = 150amps then multiples by dos equals 300amps. I think I'll be okay with 250amps for now until I fix the voltage drop. I'm looking for another optima actively.
Vmax CT800 Outback
Pioneer DEH-5000UB
  • Who's Online   0 Members, 0 Anonymous, 1672 Guests (See full list)
