SimonSezGoDwnBit Posted April 22, 2012 Report Posted April 22, 2012 i hooked a system up for my mom in her whip with a single l7 ported with a orion 2400 amp.. theres no head unit currently and its hooked up through the stock head unit with a speaker wire to rca converter on the rear speakers since the stock unit has no rca outputs... how come ill be by the amp and have both rcas input in the input and it will barely hit like it should, and once i unplug one of the rcas its 3 as loud... maybe because that converter i am using isnt putting out enough volts to the amp maybe? it doesnt make any fucking sense to me. thanks, should i just get a head unit, and a line driver/volt booster thing for her and be done with it?? will that solve this? Quote
MrSkippyJ Posted April 22, 2012 Report Posted April 22, 2012 (edited) probably have one of the speaker inputs wired out of phase. The inputs to the line out converter that is. Edited April 22, 2012 by MrSkippyJ Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
HunterJohnson Posted April 22, 2012 Report Posted April 22, 2012 (edited) I say just get a new HU. I don't like stock ones. Plus it sounds like ur high to low is janky so maybe you need to spare a few more pennies and get a decent one. I've had one that was $5 and it didnt work then I get a nicer one and everything worked fine. how many wires are going to the speaker? Edited April 22, 2012 by HunterJohnson Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
EclipseChris Posted April 22, 2012 Report Posted April 22, 2012 probably have one of the speaker inputs wired out of phase. The inputs to the line out converter that is. This, almost guaranteed. Quote i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback.
SimonSezGoDwnBit Posted April 22, 2012 Author Report Posted April 22, 2012 how can i test which is positive and which is negative with speaker wires.. do i use the 12vdc setting on my multimeter? do speaker wire output 12v to where it will read? how the fuck do i find out what is what Quote
MrSkippyJ Posted April 22, 2012 Report Posted April 22, 2012 Just flip one of them. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
412 CVX Posted April 22, 2012 Report Posted April 22, 2012 Swap the RCA's out for some new ones Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
MrSkippyJ Posted April 22, 2012 Report Posted April 22, 2012 doubt it is the RCAs Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
412 CVX Posted April 22, 2012 Report Posted April 22, 2012 Well it has to be something related to the RCA's lol. something changes when he takes one out. i had a similar problem with my very first system. one of the RCA's had a bad connection of something like that. swapped out the RCA's and i was back to bumpin Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
MrSkippyJ Posted April 22, 2012 Report Posted April 22, 2012 i would put my money on one of the LOC inputs being wired out of phase. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
