I'm looking for a new system to save up for. Now I've heard some good things about Sundown and all so I was just curious of some things.
Like what can the subs safely handle because the RMS for the SA series is only 600 watts? But I always see people pushing those harder then that so I'm curious to what they can safely handle.
If you don't have a ton of experience with the drivers, then 600-800wrms.
Though people get away with 800+wrms daily. In order to run more than the rated rms you would have to have a solid understanding of electrical, clipping, and how to design an enclosure made specifically for your power handling.
The enclosure specifications on Sundown's site are plenty efficient to run each driver off of 600-800wrms though. The SA-Series drivers are rather efficient and you'd be surprised how loud you could get off of a pair of them on a SAZ-1500d, SAE-1200d, DC 1.2K, etc.
1997 Chevrolet Cavalier Two 12" DC Audio XL M2'sCrescendo Audio BC5500d
Current Scores: 150+ out the Trunk
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
If your not too experience I'd say stick to the RMS rating, +/- 200w or so. 1500w is normally perfect for a pair for entry level setups. A lot of people I know have had great results from a 2500w amp (saz2500d for instance) but I wouldn't do that unless you atleast had a DD-1 to make sure your signal is pure and clean.
But IMO if you grabbed something a long the lines of a saz1500d you'd be set
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
And basically what CJ said, in order to driver a woofer over it's rms ratings, the answer is the same with basically EVERY driver. If you have to ask, stick to right around rms. Just saying how much a driver can handle isn't answer enough. There are quite a few factors that play into it. If you do some research and get yours hands dirty on your enclosure, rms would be surprisingly loud. I ran a single 15" SA-15 for a while in my car and was doing around a 142db @ 38Hz on about 700rms clamped.
Interestingly many companies rate less thermally and mechanically rugged products at 1000-1200 watts RMS...
We rate a bit differently using a 5+ minute 60 Hz sine wave test combined with a free air mechanical test... and the woofers must pass with flying colors to achieve a rating. Our rating is fail-safe, basically.
Edited by sundownz
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
  • Who's Online   1 Member, 0 Anonymous, 1503 Guests (See full list)
