help possible alt problems
Ok so on my way to work today my truck stalled on me. Rpms dropped real low twice and then dropped to zero and vehicle stalled. I just recently upgraded my batt to a yellowtop, did most of the big 3 in 1/0. Did i fry my alt?
Did it start up after that at all?
Just had to replace my alt in my escort a few months back.
I guess the usual signs are tach not moving or spiking everywhere, eventually your airbag light will stay on (>8v i think it triggers?), and my speedometer stood still.
Check battery voltage with a dmm, and if you're truck started up again, i;d check if you power wire possibly grounded to the alt case for a second.
check simple stuff first like the fact that the battery cables are properly connected and tightened.. coulda just ran out battery power.. other wise if you just put the yellow top in your car and it was sitting low voltage.. putting dead or drained batts in your car and letting the alt charge em up puts a huge strain on the alt, and yea they def get burned up like that.
just make sure your connections are good first. its easiest fix hopefully thats all it is
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Yea it was my alt, ended up getting a refurbished 130 amp, and got that in. Still saving towards a h/o tho. Thanks for the help.
  • Who's Online   0 Members, 0 Anonymous, 1295 Guests (See full list)
